thanks--i never knew there was a solution for this!
lost in the wilderness
Poser 13, Poser11, Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine! Win11, I7, RTX 3060 12GB
doesn't always work, however, depending on resolution of the part being displaced., or the mesh density , if you will...guess that's what causes it. I guess what I'm trying to say...is that if you use too high a displacement setting, even that will not fix the problem on lower res figures.
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
I am using displacement setting 1.0 on a black and white map in the materials room, and minimum displacement bounds setting of 1.0 for the firefly renderer.
Poser is quite vague in permissable input settings, but I guess anything beyond that could be seen as extrapolation where one is at his own risk.
Oddly enough Ch 46 of the P5 manual specifies that the renderer setting is in pixels! The displacement in my picture (in pixels) is much larger. Yet another Poser mistery.
B.
Bagoas
