Mon, Jan 27, 7:07 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Poser 6 file into Carrara 4?
Dave ( ) posted Wed, 20 April 2005 at 9:54 AM · edited Mon, 27 January 2025 at 7:01 AM
Has anyone managed to successfully import a multi-figure poser 6 file into Carrara 4? Everytime I try whatever figure is last in the scene, the other characters in the scene get the same texture applied. What I'm trying to say is I have Figure A and Figure B in the scene. When I import into the scene, Figure A suddenly has the same textures as Figure B. I could go back and edit it by hand, but I'd rather not have to do it to start with. David
Hoofdcommissaris ( ) posted Wed, 20 April 2005 at 9:58 AM
Attached Link: Look! There's even shirts with my name on it! (Dutch reads: Don't loose your head)
I think it would help if you re-name the shader to 'Hoof', before importing a second figure, which reader might also be named 'Figure 1'. By the way, any other word than 'Figure 1' will resolve the issue, probably, but I am working on my personal branding ;-)
Dave ( ) posted Wed, 20 April 2005 at 10:02 AM
But the figures are in the same P6 file, so that wouldn't resolve my problem.
MarkBremmer ( ) posted Wed, 20 April 2005 at 11:16 AM
I thought I remembered reading that the SDK for P6 hadn't been released yet meaning Eovia hasn't had the chance to update the Transposer plug to work with V6 yet.
Dave ( ) posted Wed, 20 April 2005 at 12:22 PM
Nope they haven't released it yet. Was just checking to see if somebody may have come up with a workaround until Eovia can update Transposer. David
kelley ( ) posted Sat, 23 April 2005 at 4:42 PM
I'm on the cusp of buying Transposer myself. Would the problem be solved by simply importing the figures into Carrara one at a time?
pem ( ) posted Thu, 16 June 2005 at 3:39 AM
That should do it actually and it was what I was going to suggest: divide the scene up and save it as several scenes each with one figure. I suppose this would be tedious with more than 4 or so figures though but it should work. I will test it later.
