Thu, Feb 13, 6:55 PM CST
Subject: Poser Army
arrow1 ( ) posted Fri, 22 April 2005 at 8:02 PM · edited Mon, 10 February 2025 at 10:06 PM
I am trying to import poser animated figures from Poser 5 into Vue 5 Infinite and populate them. My first figure imports ok and appears in the material Browser.I then import the second figure ok and that appears.I then put in the number I require that being 6 of one and 10 of the other.I then hit populate.They don't seem to appear in the scene at all and second when I go to render, the system locks up and I get the wretched out of memory banner.I have only so far tried to import two Daz hi res characters with limited props .What am I doing wrong? Any help appreciated.arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Polax ( ) posted Sat, 23 April 2005 at 1:17 AM
From what I know you cannot input the number of instances required directly in the ecosystem; 'scaling', 'orientation', 'presence', etc... you can. (but 'presence' does not equal final number of items.) could you post a screenshot of where you type these numbers ?
arrow1 ( ) posted Sat, 23 April 2005 at 6:55 PM
I have also tried the tutorial with Vue objects.I cannot get this too work either.I have posted screen shots.arrow1
Jcleaver ( ) posted Sat, 23 April 2005 at 7:07 PM
AFAIK, the presence fields is more of a scale, not an absolute. For example, in your image the Cazal would be 4 times more likely to appear than the Primrose. If I am wrong, then please let me know.
arrow1 ( ) posted Sat, 23 April 2005 at 7:11 PM
Can you explain a little more? I am still trying to find my way around this program.Cheers arrow1
arrow1 ( ) posted Sat, 23 April 2005 at 7:18 PM
I have tried to follow the tutorial over at e-on with the cars but it doesn't work for me either.The manual is hopeless for dummies like me! I am a visual person! Are there other settings and adjustments to be made that I don't know about for populating objects into the eco system? arrow1
Jcleaver ( ) posted Sat, 23 April 2005 at 7:24 PM
I don't think using an infinite plane will work. If you think about it, then no matter how sparse the population is, it also would be infinite. Use a regular plane and make it big enough to cover the area you want.
Jcleaver ( ) posted Sat, 23 April 2005 at 7:36 PM
Attached Link: http://www.sacada.com.au/Vue5Infinite.asp
This has been mentioned before, but here is a very good intro tutorial to ecosystems.
arrow1 ( ) posted Sun, 24 April 2005 at 3:52 AM
Many thanks.The only trouble is the tutorials are not complete.When you click on some of the index they go to a piece of artwork.Thanks again! arrow1
Jcleaver ( ) posted Sun, 24 April 2005 at 8:21 AM
I should have mentioned that! But there should be enough to get started. Hopefully they will be complete soon. I keep checking.
arrow1 ( ) posted Mon, 25 April 2005 at 1:36 AM
I am Starting to get the hang of this thanks to all the kind patience and generosity of the Vue and Poser forum.I have one question? In jwhitham's tutorial on his animation script he says "First off assess how far the full scale figure to be used in the EcoSystem travels per second, in Vue logical units. This is needed to correctly synchronise the figures strides with ground covered" I am at loss to know what he means! Can anyone show me how to do this? I seem to be ok with the rest of the tutorial. Cheers arrow1
