Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Hi Spencer, I had the same experience. If you browse for P6 and click OK then the installer does actually update a few files even though it appears to die instead of the usual graceful exit etc. Check the file list against the P6 directory to see if the updated files are there. Hope that helps, Indoda
The important thing is not to stop questioning.
- Albert Einstein
Indoda
Hi Spencer, There's definitely something strange going on with that installer. I just checked again and I don't have a winter coat (maybe it's because it's spring in the Northern Hemisphere LOL) Other files are missing too I have one (fbra2.obz) that's a zero byte file. Sorry I'm not much help either - I downloaded the file 3 times and no change. WinXP Home, P5, P6 upgrade download version Anyone else care to check for the files that are supposed to be in the installer, TIA
- Albert Einstein
Indoda
Yeah I had the same problem. I downloaded the update no problem, but when I went to run it, it couldn't find Poser 6 either. It ran for 2 seconds then nothing. I even tried to install it into a temporary runtime, but nothing was installed (runtime shows 0 bytes). The missing files in Poser 6 are still missing....
Hi Spencer, That did the trick - but I hope that's not going to be the way for every update ;( something got missed out of the registry or something. Horrible way to check for an installation. That VISE installer is not up to much either I noticed (installed from my CD this time not HD) that it stuck on one particular .png file for 90% of the install time was not updating the screen. Thank you. Happy Posing. I still have a zero byte file - fbra2.obz?
- Albert Einstein
Indoda
Hi, I just downloaded the content update and I had problems with the install. The .exe installer firstly reports that Poser 6 is not installed on the system and invites you to browse for it. You do so and identify the programme location, a progress bar is then displayed for about two seconds and then nothing - The CuriousLabs installer does not appear to know anything about the Windows file system and no matter where you point it it does not install anything anywhere.
It appears to bomb out after doing some checking.
I know that other people have experienced exactly the same problem.
Has anyone been able to install this update succesfully?
