Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=938557
You're right Hoof, every 3D lover should do a chess set. This was surprisingly satisfying, thanks for the challenge Kix.There's an odd angle render of this in my gallery on the link attached.
Scott
Kixim, small problem with your set. King and queen are in the wrong place and they are lined up on the wrong side. Ok, being fussy. Both look good. Sdnobles looks very elegant. Sdnoble, how did the close up switch the king and queen? Yet it's fine in the first render. Still working on mine. Never made a chess set before in 3D. I guess it's about time. Is there a time limit of 30 min? If so I've blown it easily. :P
Everything done with the vertex modeller. Some simple boolean subtraction for some parts but most are actually quick and dirty modelled. Meaning, I didn't bother to make them perfect; the black rook for instance, there are actually a couple of pipes intersecting itself instead of one clean mesh. You'd probably see that if I made the solid glass or something.
A bit of a shame you don't seem much of the tressle work under the board. Ah well. Small part of the whole anyway.
But man, those tiny screews on the corner really slowed the render down. :/
Message edited on: 04/25/2005 18:05
-Kix
