Fri, Nov 29, 10:22 PM CST
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Nov 24 8:50 pm)
Check out the
Subject: Freeware patch modeller
BazC ( ) posted Mon, 18 April 2005 at 2:01 PM · edited Fri, 29 November 2024 at 10:18 PM
Attached Link: http://www.jpatch.com/
I just discovered JPatch, it runs on any platform that can run Java based apps. I've only played with it briefly but it seems pretty good! I'm not sure if this is a true NURBS modeller or not but it looks like a similar idea - Baz
pakled ( ) posted Tue, 19 April 2005 at 4:50 PM
sounds like a winner..;) thanks
BazC ( ) posted Wed, 20 April 2005 at 1:34 AM
You're very welcome! :o)
pauljs75 ( ) posted Wed, 20 April 2005 at 3:40 AM
This app looks pretty dang cool. Hopefully it doesn't respond like the other Java programs I know. They're pretty cool too (such as arbaro for making trees), but in my experience Java would have one big thing against it for doing things in real time... Itsssss ssslllloooooowwww... (At least on my 'puters) But then again, it could just be that those programmers did things the hard way. I'll still have to check. :)
Barbequed Pixels?
BazC ( ) posted Wed, 20 April 2005 at 4:58 AM
Have you figured out Arbaro Paul? I recently downloaded it and haven't got very far with it. I could do with some simple tuts but I can't find any. Mind you I haven't looked very hard lol! - Baz
pauljs75 ( ) posted Wed, 20 April 2005 at 7:03 PM
I recently gave it a shot and was actually suprised that the working environment was actually fast, unlike most other Java based programs I've tried. So that's a good thing. :) However it seems to lag quite a bit much on typical windows tasks like pulling up directories. Also I'll have to go over some stuff, as I don't know how to connect points or other things which are much more intuitive in other programs. Lathe seemed fun... But I'll need to do some more figuring out before I can deem it useful. I wouldn't knock it... It might be the way to go if you're not really into poly/sub-d modeling. BazC: I do understand arbaro a bit, you just have to play with the different settings. (There are some others around who know it better, because I haven't been playing with trees in my renders a whole lot. Poke around on the Bryce forum a bit.) Basically you're setting the extents to which it randomizes various parts of the tree's geometry. And it can be a bit slow. Perhaps it trys to do more than my compy can handle. (Better coding might try to detect memory and set appropriate limits. But what do I know?) Also I think there are some settings that can be lowered to make resulting models less poly heavy.
Barbequed Pixels?
BazC ( ) posted Thu, 21 April 2005 at 2:02 AM
Cheers Paul! I had another quick play yesterday and it's a little clearer than it was! It's figuring out what all the different parameters actually do that takes so much trial and error lol! I have heard it creates pretty weighty models, I hadn't noticed any poly reduction tools or resolution controls but I suppose they must be there somewhere! :o)
danamo ( ) posted Thu, 21 April 2005 at 10:19 PM
Hi Baz, thanks for the link! I'll have to d/l it and play with it a bit. I like Arbaro and have had some success with it. It does tend to make some poly-heavy models, but
they hold up real well next to the camera like a "hero tree" should. I've found that .dxf format is the way to go as far as export for this app. The object file format tends to make the app hang, especially with complex models.
You may have to manually add ".dxf" or ".obj" when you name your file.
BazC ( ) posted Fri, 22 April 2005 at 2:25 AM
Thanks Danamo! Arbaro looks like a good alternative until I can afford XFrog! :o)
brainmuffin ( ) posted Sun, 24 April 2005 at 10:39 PM
J-Patch is not actually true NURBS. It actually works more or less exactly like Hash Splines.
BazC ( ) posted Mon, 25 April 2005 at 1:01 PM
Ah! Thanks for the info!
emmar ( ) posted Mon, 25 April 2005 at 3:44 PM
Attached Link: http://ayam.sourceforge.net/ayam.html
If you want free NURBS modeler try Ayam.
pauljs75 ( ) posted Mon, 25 April 2005 at 4:22 PM
Ooooh! Another free modeler. I wonder if pakled is keeping his list up to date. Sourceforge rocks!
Barbequed Pixels?
danamo ( ) posted Mon, 25 April 2005 at 5:04 PM
I agree; Sourceforge does rock!
swishy ( ) posted Mon, 25 April 2005 at 5:16 PM
Ayam looks interesting. It took me a little while to figure out that it's Maya reversed though - oh, I'm slow these days. :)
swishy
danamo ( ) posted Mon, 25 April 2005 at 9:04 PM
Attached Link: POVtree
Here's another cool Java-based tree-making app. called POVtree. It outputs POV .inc files, but luckily I found a freeware app that would convert the files to .obj format. http://user.txcyber.com/~sgalls/ The output seems pretty spectacular from the presets I've tested so far; kind of like a poor person's X-Frog! Here's a picture of the "olive tree" preset rendered as a quickee in Bryce.
pauljs75 ( ) posted Mon, 25 April 2005 at 11:16 PM
Maya backwards, yes. I didn't notice that right away. Also it could be an acronym for And Yet Another Modeler. So it works on two levels. LOL!
Barbequed Pixels?
BazC ( ) posted Tue, 26 April 2005 at 3:18 AM
Very cool links, thanks! I really like the look of POVtree, hope there's a POV to .obj converter for Mac somewhere! - Baz
nruddock ( ) posted Tue, 26 April 2005 at 3:52 AM
There is also Arbaro which has a built-in OBJ exporter.
BazC ( ) posted Tue, 26 April 2005 at 4:17 AM
thanks nruddock, I have Arbaro, I just like the look of POVtree! :o)
