Sun, Jan 5, 6:19 AM CST
Subject: is it possible to........realtime update while editing a texture map?
anxcon ( ) posted Wed, 27 April 2005 at 11:39 AM · edited Wed, 25 December 2024 at 7:14 PM
doesnt matter if i use poser, or another program but basicly i want a model in a 3d window, like poser the texture map is applied to it, and it shows like a quick preview of the texture on the model then a 2nd window, have the basic setup from a paint program like psp or photoshop or something basicly and while pixels are painted, it updates the picture in the 3d window (realtime update) example, painting a beard texture map for a face while having a 3d view of it in use probably need a 3rd app to watch ram as poser and psp run? then edit poser loaded maps as the maps in psp get edited (i have 3 monitors, so poser/psp up isa workable) or is there another app to do it all in 1? as long as it can load the mesh and use same texture maps as poser, would work fine
jancory ( ) posted Wed, 27 April 2005 at 11:46 AM
try uvmapper pro. i use it w/pshop to check my textures as i make them. it's GREAT.
lost in the wilderness
Poser 13, Poser11,  Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine!  Win11, I7, RTX 3060 12GB
 My Freebies
anxcon ( ) posted Wed, 27 April 2005 at 11:56 AM
i want it update the 3d view as i edit the map not reload map every few minutes it does that?:P
JenX ( ) posted Wed, 27 April 2005 at 12:34 PM
Attached Link: Right Hemisphere, maker of Deep Paint
I know that you get a sort of 'real-time' view out of Deep Paint, but it's VERY resource heavy (at least on my machine, which I'll definitely say is not a good one, LOL). It's good for texture making, but it's got a steep learning curve ;) I've only tried the demo, because my system just doesn't like it.
vilian ( ) posted Wed, 27 April 2005 at 1:20 PM
Or you can try Prop Viewer by kawecki (in Freestuff section). I use it quite often, since it's much lighter on the system than Poser, especially with graphic program already launched. You have to reload texture manually every time, but it's good for quick check. Unfortunately there's no zoom option :(
Outdated gallery over at DeviantArt
Fics at FanFiction.net and Archive of Our Own (AO3)
kuroyume0161 ( ) posted Wed, 27 April 2005 at 1:23 PM
There is also BodyPaint3D by MAXON. I think you are asking alot! In order to transport information from PSP or PS while editing to another application will require a constant Clipboard update - something that I'm pretty sure isn't available in either. Unless someone writes plugins for PSP/PS and Poser that seamlessly interact to this end, it may be a cold day in Hades before such a thing is possible. Note that both BodyPaint3D and DeepPaint edit the texture directly in the application with the geometry present.
 -- Bjarne Stroustrup
kuroyume0161 ( ) posted Wed, 27 April 2005 at 1:27 PM
I should like to add that it would be great to have a less powerful application just for this purpose. Both BodyPaint3D and DeepPaint are UV mapping/texturing applications. Since Poser figures are already UV mapped, for interactive painting, this should reduce the complexity of the application greatly. What you are looking for is a 3D object paint program to create your textures. Does one exist? Let's see... :)
Posermatic ( ) posted Wed, 27 April 2005 at 1:51 PM
There was 3DPainter by Fractal design, but don't know what happened with it after Fractal dump all it's software. It was very light in resources and give you realtime update and the best part was it's price. I'm going to do a quick search.
RawArt ( ) posted Wed, 27 April 2005 at 3:17 PM
This may be of interest to you http://www.blacksmith3d.com/index.html
SamTherapy ( ) posted Wed, 27 April 2005 at 4:13 PM
"i want it update the 3d view as i edit the map not reload map every few minutes it does that?:P " Yes.
DustRider ( ) posted Wed, 27 April 2005 at 7:07 PM
Attached Link: http://www.terabit.nildram.co.uk/tattoo/
Have you looked at Tatoo? It's free for non-commercial use. I use BodyPaint, so I haven't ever really tried it. But it might be worth looking into.
__________________________________________________________
My Rendo Gallery ........ My DAZ3D Gallery ........... My DA Gallery ......
SWAMP ( ) posted Wed, 27 April 2005 at 8:47 PM
Actually I think Poser was meant to do just that. I have an old program that I still use a lot called Canoma. MetaCreations and the crew that brought you Poser made it. It is a simple modeling program that allows you to open images and pin 3D shapes to them creating buildings, interiors, or complete city scenes (or animations). One of the features is that you can click on a paint tool and Photoshop, Painter or whatever image editor you have set in preferences will open with that image (or texture). You can then edit with any tool or filter in your image editor and it is updated right back in Canoma. Note:It doesnt use the clipboard but caches the files within the program itself. Several months back I posted a way to speed up the library display in Poser. It involved cutting the connection to QuickTime that was giving Poser fits with newer versions of QT. While reading all the program files in Poser to find all the links, I noticed a lot of references to Photoshop and Photoshop filters within them. So I think most of the coding is indeed in place within Poser but is just missing the link to the image editor. Why did MetaCreations stop short on this really cool feature? Adobe bought Canoma just when it hit version 1.1 for (from what I have read) a very hefty price. Because Adobe never offered it for sale, my thinking is they purchased it for the technology then buried the product in their backyard (something Adobe is know to do). Im sure the deal included for Meta to not use that technology in their other apps. Would have been really nice. SWAMP
odeathoflife ( ) posted Thu, 28 April 2005 at 2:05 AM · edited Thu, 28 April 2005 at 2:10 AM
Damn I am going to have to take Canoma for a spin :) Edited to add that I also use Painter3d by Metacreations to paint when I do not use a 2d painter. I do believe that from my demo's of right hemispheres deep paint that this is the latest incarnation of Painter3d but I could be wrong, they seem to be about the same program with teh newer one of course being a lot more powerful
Message edited on: 04/28/2005 02:10
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
anxcon ( ) posted Thu, 28 April 2005 at 1:03 PM
tried tatoo, but memory limits of the program wont let me load V3? deep paint costs alot of money >_> and canoma isnt even able to be bought :x
SWAMP ( ) posted Thu, 28 April 2005 at 6:54 PM · edited Thu, 28 April 2005 at 7:03 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1673034
Well Canoma isn't really what you are looking for to make textures for Poser people. I was only using that as an example in my discussion about the coding I found in Poser.
Tattoo is very low end and is good for only simple props.
Deep Paint is VERY expensive, and resource hungry (crashes a lot).
There is one more option, and that is Maxons stand alone Body Paint.
It is not cheap but compared to Deep Paint its a bargain (I believe around $700.00).
You do get a lot for your money though.
You get an excellent 3D paint/texture program (also uses Photoshop filters).
A VERY sophisticated built-in UV mapping program.
And the standard Cinema4d render engine,cameras,lights and materials options (VERY nice!).
There are free plugins that allow you to bring in complete Poser scenes with textures and ready to render.
It will take any modules, plugins or shaders made for Cinema like Advanced Render where you get radiosity, SSS and true HDRI.
In other words its just like the complete Cinema4d Studio bundle without the modeling and animation features.
They do have a demo to try.
Here is a link where some of us were chewing the fat about 3D paint programs.
SWAMP
Message edited on: 04/28/2005 19:03
anxcon ( ) posted Fri, 29 April 2005 at 12:16 AM
considering i need it for only like 5 maps......$700 is just :x
Jim Burton ( ) posted Fri, 29 April 2005 at 3:46 PM
I guess you know you don't have to "reload map every few minutes", just save it in Photoshop and have Poser re-render, which will update the preview, too. You can even set it to render to a tiny little window to speed things up. Not what you want but better than nothing. I looked at this same thing awile ago, and coudn't finfd anything at the price I wanted to spend. Poser 4 used to come with a program (whoes name excapes me) that did EXACTLY what you want, for free, but it will not run on newer systems.
