Thu, Nov 14, 8:38 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: Help please!!! :)
Emanaia ( ) posted Mon, 25 April 2005 at 1:21 PM · edited Thu, 14 November 2024 at 8:37 AM
I am slowly and painfully trying to learn poser and have run into yet another snag. Once I render the figure I have attempted to make and tried to save it, the only option I am given is to save it as a Poser file. What do I need to do to be able to save it as a JPEG? Thanks sooooo much for your help!! :)
Rance01 ( ) posted Mon, 25 April 2005 at 1:28 PM
Try File, Export Image. Best Wishes, Rance
JenX ( ) posted Mon, 25 April 2005 at 1:28 PM
Have you tried "Export Image"? I'm not sure if that option is in Poser 4 or PP, since I don't use them, but in Poser 5, the option should be in the file menu. Make sure, though, when you use "Export Image", that your image is still rendered. hth! MS
Emanaia ( ) posted Mon, 25 April 2005 at 1:36 PM
I'll thought I had tried that and was not given the option but I will go look again. I am in Poser 6. Thanks for the help!
I thought I had tried that and was not given the option but I will go look again. I am in Poser 6. Thanks for the help!
operaguy ( ) posted Mon, 25 April 2005 at 2:16 PM
in poser 6, click on a little icon (looks like a hand or bucket) above the render. That breaks the image out into a separate window. Hit the close "X". It will ask you if you wish to save. There are save choices in the next dialog, including various qualities of jpg. ::::: Opera :::::
Acadia ( ) posted Mon, 25 April 2005 at 3:11 PM
I find that I get that option after a render if I have rendered in the pose window. It then asks me to save the .pz3 file first, and then it allows me to save the .png/.tif/.jpg image. I always render in a separate window (same size as my pose window 800 x 800) now. I always save the .pz3 before rendering anyway, this way I don't get asked to save it again after the render.
operaguy ( ) posted Mon, 25 April 2005 at 4:09 PM
how do you render to a second window in poser 6 acadia?
Acadia ( ) posted Mon, 25 April 2005 at 4:28 PM
Gosh, I don't know. I use Poser 5. In Poser 5 you make those choices in your Render options window. It allows you to change the size of the render window and either have it render as a separate window, or render in the existing pose window.
Emanaia ( ) posted Mon, 25 April 2005 at 4:36 PM
Ok, finally got it straight. For those of you that may not know for Poser 6, (Actually the first version I have ever used YIKES)to save what you have rendered you DO go to Export and then click on Image and it allows you to save as a JPEG. I do have more questions but I will give you all a breather LOL Thanks for all your help!!
Fazzel ( ) posted Mon, 25 April 2005 at 10:46 PM
And not just as a jpeg. You can also save it as a .bmp, a .tiff, a .png, a photoshop .psd, and a couple others I'm not familiar with. PS, when you save a jpeg, make sure you use the quality you want, the bigger the number, the better the quality. I like 90 to 95, but if you are pressed for hard disk space you can go lower.
douglaslamoureaux ( ) posted Mon, 25 April 2005 at 11:28 PM
This is one of my pet peeves. P6 changed a simple task into a complex task. Why CL changed the way to save pictures in P6 from the way P5(or P4 or P3 or P2) did it, and made it more difficult to boot is beyond me. Sure its probably mentioned in the manual. Sure we can figure it out with a little trial and error. I do it the same way Opera does it. (oops I was about to launch into an all out rip on P6 and completely off-topic :-o I'd better stop before I get all riled up about P6.
operaguy ( ) posted Tue, 26 April 2005 at 12:44 AM
i've come to really like the way P6 saves your string of renders and allows you to compare them by choosing from two lists and then scrubbing and changing from one to another. The way I used to work was no easier (and did not feature the comparision), namely render to a new window and then either close/save or right click and save as. Also, continuing what Fazzel said, you can save as TIFF and PNG which are lossless, and contain an alpha channel. This is very usefull and important. Hurray to Poser6 render saving. ::::: Opera :::::
Emanaia ( ) posted Tue, 26 April 2005 at 7:50 AM
What I can't figure out how to do though is to make the figure bigger. If I make her too big then she goes off the screen and when you do save it, you don't get the huge pic you wanted, you just get what you were actually able to see. Does that make sense?
Emanaia ( ) posted Tue, 26 April 2005 at 7:52 AM
Attached Link: http://www.deviantart.com/deviation/17646947/
Oh! And by the way I finally finished my first attempt! WOOOHOOO! LOL If you are interested in seeing it just go to http://www.deviantart.com/deviation/17646947/ Thanks for all the help guys! Much Love!
Richard T ( ) posted Tue, 26 April 2005 at 6:00 PM
Attached Link: http://www.poseruniverse.com/Tutorials/P5P6_101_1.html
You may like to look here. It's for P5, hwever the same pricipals apply to P6.
Emanaia ( ) posted Wed, 27 April 2005 at 7:16 AM
Thank you! I will go look.:)
Richard T ( ) posted Wed, 27 April 2005 at 8:33 AM
There will be a P6 specific tut in a day or so (working on it now). Will notify when it is up. Richard
Emanaia ( ) posted Wed, 27 April 2005 at 10:27 AM
Thank you :)
Richard T ( ) posted Wed, 27 April 2005 at 4:08 PM
Attached Link: http://www.poseruniverse.com/Tutorials/P6_101_1.html
Here you go. There is some Poser screen shot nudity. http://www.poseruniverse.com/Tutorials/P6_101_1.html
Emanaia ( ) posted Wed, 27 April 2005 at 4:14 PM
Oh cool! I will go take a peek! Thank you!
Emanaia ( ) posted Wed, 27 April 2005 at 4:24 PM
Richard, that looks like it is going to be an extremely helpful tut for making my end pics bigger. Thanks so much! :)
Richard T ( ) posted Wed, 27 April 2005 at 4:27 PM
Glad to be of help, Richard
