I was going to suggest checking the normals until I read on. What about Angle Start and Angle End? They will affect the brightness and "throw" of the beam.
Could it be that the object is built without any UV values? Try running it through UVmapper to give it some kind of a map, and save the model after assigning the map. (I've noticed this in Poser 6, with things that I build in Amapi.)
My python page
My ShareCG freebies
In the material room, on the Image Map node. There are several settings you can use to adjust the way textures are applied. It does, however, only work for image maps. It will not work for shaders.
If the object renders black no matter of the colour you assign to it: 1) The mesh has wrong faces(face with only two vertices or face with repeated vertices indexes) 2) Duplicated faces (the same face repeated) 3) Double face (two same faces with opposite normals) ------ Reversed normals only affect preview mode, the object render normaly unless you check the backculled option in Firefly. Wrong UV or lack of them only affect the texturing, if you don't use texture map the object have to work properly.
Stupidity also evolves!
Nigel, I'm in P5, and the lights don't have specular settings as far as I can see. Oddly, I solved my problem by setting the intensity far above 100%, and it seemed to work, as you will see if you look at my new gallery image entitled "Eat Me" (It was the monstrous face on the left that I had difficulty illuminating.)
Have any of you ever experienced a scene where no matter how hard you shine a light on an object, it refuses to become illuminated? I've checked the Dist start and end settings, they are not a problem. I've trashed and relit the scene, and still no luck. In the past, sometimes objects won't accept light until the normals are reversed, but that is not a fix in this situation I'm dealing with. Any ideas?
