Mon, Dec 23, 11:03 AM CST
Subject: Difficulty getting an object to accept lighting...
pookah69 ( ) posted Thu, 28 April 2005 at 1:05 PM ยท edited Mon, 23 December 2024 at 11:02 AM
Have any of you ever experienced a scene where no matter how hard you shine a light on an object, it refuses to become illuminated? I've checked the Dist start and end settings, they are not a problem. I've trashed and relit the scene, and still no luck. In the past, sometimes objects won't accept light until the normals are reversed, but that is not a fix in this situation I'm dealing with. Any ideas?
SamTherapy ( ) posted Thu, 28 April 2005 at 1:14 PM
I was going to suggest checking the normals until I read on. What about Angle Start and Angle End? They will affect the brightness and "throw" of the beam.
ockham ( ) posted Thu, 28 April 2005 at 1:22 PM
Could it be that the object is built without any UV values? Try running it through UVmapper to give it some kind of a map, and save the model after assigning the map. (I've noticed this in Poser 6, with things that I build in Amapi.)
My python page
My ShareCG freebies
operaguy ( ) posted Thu, 28 April 2005 at 1:39 PM
even a non-controversial object like a sphere will not relfect light? did you throw away the light and create a new one? I am sure this is a 'way undershoot' but it is not by chance a spotlight pointed away from the objects, is it? What about a scale problem? ::::: Opera :::::
ynsaen ( ) posted Thu, 28 April 2005 at 1:45 PM
If an item lacks a uv map in p5/6, change the image node UV settings to None.
pookah69 ( ) posted Thu, 28 April 2005 at 1:54 PM
How does one change the image node UV settings?
ynsaen ( ) posted Thu, 28 April 2005 at 2:09 PM
In the material room, on the Image Map node. There are several settings you can use to adjust the way textures are applied. It does, however, only work for image maps. It will not work for shaders.
kawecki ( ) posted Thu, 28 April 2005 at 6:16 PM
If the object renders black no matter of the colour you assign to it: 1) The mesh has wrong faces(face with only two vertices or face with repeated vertices indexes) 2) Duplicated faces (the same face repeated) 3) Double face (two same faces with opposite normals) ------ Reversed normals only affect preview mode, the object render normaly unless you check the backculled option in Firefly. Wrong UV or lack of them only affect the texturing, if you don't use texture map the object have to work properly.
Stupidity also evolves!
nghayward ( ) posted Fri, 29 April 2005 at 2:58 PM ยท edited Fri, 29 April 2005 at 3:03 PM
The only difference between these two renders was the diffuse color of the light. Was yours black?
Nigel.
Message edited on: 04/29/2005 15:03
nghayward ( ) posted Fri, 29 April 2005 at 3:16 PM
By the way in the renders I posted above the hair texture was plugged into the translucence_color node so it will show up even if there are no lights at all! Nigel.
pookah69 ( ) posted Fri, 29 April 2005 at 4:28 PM
Nigel, I'm in P5, and the lights don't have specular settings as far as I can see. Oddly, I solved my problem by setting the intensity far above 100%, and it seemed to work, as you will see if you look at my new gallery image entitled "Eat Me" (It was the monstrous face on the left that I had difficulty illuminating.)
