Sat, Feb 1, 10:04 PM CST
Subject: Lightwave-vue mapping probs please
stella6488 ( ) posted Fri, 29 April 2005 at 5:54 AM · edited Sat, 01 February 2025 at 9:58 PM
G'Day there, newie Vue user, trying to creat architecural objects in Lightwave then using UVmapper (classic), for textures, (appears ok, mapped in LW), bu when imported into Vue (4.05), as per above images, mapping is ??, shall we say, way off. Any help, advice, links to tuts, would be appreciated. LW version in 7.5, Vue 4.05. Ta.
wabe ( ) posted Fri, 29 April 2005 at 6:16 AM
Any reason why you haven't updated to the actual version of Vue 4? 4.22 is the newest when i remember it right. You should try that as #1. You haven't said from which format you imported into Vue. obj? 3ds? lwo? Maybe you try other formats as well. As well you can change the mapping method here. I know - as we all can see every day in the gallery - that the import works fine with Poser models. Including the correct positioning of the maps. And with 3ds too - i use that a lot, even when my Vue 4 days are over a long time ago.
stella6488 ( ) posted Fri, 29 April 2005 at 6:26 AM
yep it was an obj file, will also try to locate teh 22 update. thanks a lot for the quick response. PT..
stella6488 ( ) posted Thu, 05 May 2005 at 2:15 AM
Updates to 4.22, still same result, will keep at it, thanks Wabe..
phenom01 ( ) posted Thu, 05 May 2005 at 9:14 AM · edited Thu, 05 May 2005 at 9:18 AM
Hi. Depending on how you saved your map, you may have to flip or rotate the image. Most often it is just a matter of flipping the image vertically. First, try replacing the 1.000 in the "Picture Scale Y" edit box with -1.000. HTH
Message edited on: 05/05/2005 09:18
