You should beable to. It does sound strange. I always uncheck Universe and don't have problems. This may sound dumb but are there morphs on that bodypart? Regards, Anton
-Anton, creator of Apollo Maximus
"Conviction without truth is denial; Denial in the
face of truth is concealment."
Not sure if it is or isn't attached to other export by default. I only work with obj so have never looked to see. I sounds like your Poser is definately bugged for some reason if you can't even select options. Sounds like really you have to contact CL tech. That just isn't normal at all. Sorry.
I know I'm missing something simple. No matter what I try when exporting an OBJ, I can't select the box, "As Morph Target." In fact there are several I can't select. Yes, I've unchecked "Universe" and selected only one body part. I think I've tried every set of options when trying to do this. So please be specific with your suggestions. Just assume I'm nearly brain dead by now. Any help will be very much appreciated!
