Sun, Jan 26, 2:51 PM CST
Subject: Can't choose "As Morph Target"
sakelsey ( ) posted Sat, 30 April 2005 at 6:05 AM · edited Sun, 26 January 2025 at 2:50 PM
I know I'm missing something simple. No matter what I try when exporting an OBJ, I can't select the box, "As Morph Target." In fact there are several I can't select. Yes, I've unchecked "Universe" and selected only one body part. I think I've tried every set of options when trying to do this. So please be specific with your suggestions. Just assume I'm nearly brain dead by now. Any help will be very much appreciated!
byAnton ( ) posted Sat, 30 April 2005 at 6:11 AM
You should beable to. It does sound strange. I always uncheck Universe and don't have problems. This may sound dumb but are there morphs on that bodypart? Regards, Anton
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
sakelsey ( ) posted Sat, 30 April 2005 at 6:30 AM
Yes
byAnton ( ) posted Sat, 30 April 2005 at 6:31 AM · edited Sat, 30 April 2005 at 6:32 AM
You are exporting as .obj?
Message edited on: 04/30/2005 06:32
sakelsey ( ) posted Sat, 30 April 2005 at 6:52 AM
Isn't that the only way to get that dialog box?
byAnton ( ) posted Sat, 30 April 2005 at 7:13 AM
Not sure if it is or isn't attached to other export by default. I only work with obj so have never looked to see. I sounds like your Poser is definately bugged for some reason if you can't even select options. Sounds like really you have to contact CL tech. That just isn't normal at all. Sorry.
Dagon ( ) posted Sat, 30 April 2005 at 7:43 AM
randym77 ( ) posted Sat, 30 April 2005 at 8:31 AM
I just right-click on the Windows clock, in the bottom right of the screen. Adjust date and time, then cancel. (You don't have to actually adjust the date or time.) Then exporting OBJs works. Anton, I'm afraid it is perfectly normal. A long-time, if intermittent, Poser bug.
byAnton ( ) posted Sat, 30 April 2005 at 7:14 PM
Really?!? I had bever heard of that. How aweful and strange. I am so glad I haven't encountered that. SOunds like a huge pain.
