Thu, Nov 14, 11:25 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: Can POSER import Terragen terrains?
urusei ( ) posted Sat, 30 April 2005 at 2:31 PM · edited Thu, 14 November 2024 at 11:24 PM
No matter what format. Thanks
pakled ( ) posted Sat, 30 April 2005 at 2:45 PM
welll....yes and no. There's a plugin out there somewhere, called FEO (for export only), that allows you to export to a more commonly-recognized format (I think Lightwave's lwo). The trick is scaling. Poser's scaling vis a vis other programs is something else. Poser exports are tiny in other programs. Poser imports some things as gargantuan..;)
What you might want to try is rendering in Terragen, then taking the picture and exporting as the background. Dr. Geep has a background tutorial that explains how..
jancory ( ) posted Sat, 30 April 2005 at 3:01 PM
there's a link to the FEO plugin on the Terragen community page---it lets you export .obj from terragen & yes they do import into poser ok (i just tested one).
lost in the wilderness
Poser 13, Poser11,  Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine!  Win11, I7, RTX 3060 12GB
 My Freebies
OrcaDesignStudios ( ) posted Sat, 30 April 2005 at 4:14 PM
If you can export your terrain as a greyscale image, you could also use it as a displacement map on a high-res square in Poser 5 or 6.
urusei ( ) posted Sun, 01 May 2005 at 9:34 PM
Thanks
