Forum Moderators: Wolfenshire, Deenamic Forum Coordinators: Anim8dtoon
Photoshop F.A.Q (Last Updated: 2024 Sep 19 10:49 pm)
Attached Link: http://www.chrishammondonline.com
If I understand your question right, you want to get a selection around your object. If your object is all by its self on a layer hold CTRL and click on the layer. If its not on its own layer try using the magic wand to select what you want, play around with the settings for this tool. If you want to draw a line on your selection go EDIT>STROKE, if you want to make the selection bigger or smaller go SELECT>MODIFY>EXPAND OR CONTRACT. I hope that helps Chris HammondDepending on the image, a possibility is to check out the colour channels. Choose the one giving the best contrast between the background and the object you want to outline. Copy that to create a new alpha channel. Boost the contrast using levels and fill in relevant areas with black/white. Once happy with the result, copy this again to create a 2nd alpha channel. Use filter / other / max / min to increase the masked/selection area. You can then difference these two alpha channels to create your outline directly or use them for stroking/stroking path purposes. Hope this complements other method - use whatever gives the best? results - creating spare alphas also gives you the chance to experiment with other effects like blurs/grads etc If originally in RGB, and having trouble, try CMYK or LAB to see if they offer any other options.
Attached Link: http://www.alienspeek.demon.co.uk
There is an amazingly easy way to do this IF the object images whatever are on a transparent background .. just go to > Select > choose load selection and however complex it will select the entire outline .. choose new layer and stroke under > Edit > link the new stroked path to the layer it was selected from ... that way you havent stroked the origional layer.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I've used PS for a long time but I have never had a need to outline an object until now. So what is the best method to outline any given shape/image/object with any given complexity? Images from simple shapes to complex images with little nooks and crannies and protrusions on the edges. Thanks!
