Sat, Feb 1, 8:39 AM CST
Subject: Safe Housekeeping?
FranOnTheEdge ( ) posted Sat, 30 April 2005 at 5:27 PM ยท edited Sat, 01 February 2025 at 5:59 AM
Okay, I want to add lots of the objects, materials and textures that I had in Bryce4 to my Bryce 5.
How many are safe to add? How many are too many?
Plus: How do I save those library files once I have everything in there that I want?
Fran (Oh, I mean "save" as in for back up purposes, in case Bryce does this scary emptying the presets folders, that I've just heard about.) F
Message edited on: 04/30/2005 17:29
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
AgentSmith ( ) posted Sat, 30 April 2005 at 5:36 PM
I would think it would be alright to add as many as you wish, unless you have a small amount of system RAM, you might just want to go slow. Ah, saving/backing up, VERY important! You can select a catagory, and then selct what mats you want by the same way you would select files in Explorer, with shift or ctrl + click. When you select them, a hard to see red outline will appear around each .mat thumbnail. When you have all the ones you want selected, just export to another location for backup purposes. AS
FranOnTheEdge ( ) posted Sat, 30 April 2005 at 5:53 PM
Yes, but in what do you save the files? In Windows Explorer? I can do that standing on my head, it's doing it any other way that I may need instructions for.
Fran's Freestuff
AgentSmith ( ) posted Sat, 30 April 2005 at 6:09 PM
Hold on, someone made a "how-to" little screen capture at one point, let me see if I can find it. ;) AS
AgentSmith ( ) posted Sat, 30 April 2005 at 6:35 PM
Rofl...yeah, I found the old thread...it was ME that made the screen capture...almost two years ago, man how time flies! AS
AgentSmith ( ) posted Sat, 30 April 2005 at 6:42 PM ยท edited Sat, 30 April 2005 at 6:43 PM
Okay, now WHERE you back them up can be important also, if you can;
Back them up on a SEPERATE hard drive, and/or burn them to a blank CD/DVD.
If you can't do that, at least back them up outside of your Bryce folder, that way if your Bryce program explodes, you can still re-import later.
SECOND great reason to export mats (and back them up)...if you for any reason don't want a mat and delete it...it doesn't actually delete, Bryce will just remove the thumb for it.
From time to time, selecting which mats you want to keep, exporting them out, then manually deleting the preset, by hand, in windows explorer, and then re-importing what you just exported, will truly get rid of any hidden but not truly deletd .mats
AS
Message edited on: 04/30/2005 18:43
FranOnTheEdge ( ) posted Sat, 30 April 2005 at 7:43 PM
I'm afraid I'm a hoarder, I never want to get rid of ANYTHING. Well.... you never know, do you? (guilty expression) Fran
Fran's Freestuff
pakled ( ) posted Sat, 30 April 2005 at 8:07 PM ยท edited Sat, 30 April 2005 at 8:11 PM
you can store the mats as files. I have a directory of mats with over a thousand.
As for usage, I seem to find you can get about 250 or so in the materials section before things get whacky. Now one thing you can do is to create subdirectories, under the User section. It's a great way to categorize stuff, such as metals, organics, building materials, etc. Copy the user.mat (you'll find it in c:Program FilesCorelBryce 5PresetsMaterialsUser)
and copy it as another name (if you have nothing in the user file so far, so much the better)
Once you've created the files, you can import each mat into whatever category you like (each filename will show up as a file, see attached). On to stage 2.
Message edited on: 04/30/2005 20:11
pakled ( ) posted Sat, 30 April 2005 at 8:09 PM ยท edited Sat, 30 April 2005 at 8:11 PM
Now, here's how you add them in.. Just import to the categories as you see fit. Just use the import function to add. Hope this helps.
skiwillgee ( ) posted Sat, 30 April 2005 at 10:50 PM
If loss of material files is a real issue, can the material lab file with all its contents be identified and saved? Like Franontheedge, this concerns me because you guys have gotten me off my duff and am trying to create my own mats so hopefully my files will be growing. Sure don't want to lose
AgentSmith ( ) posted Sat, 30 April 2005 at 11:00 PM
Sure, when you save a .mat, everything that could possible make up the materail is saved in the .mat file, even if it is an image texture that makes up the mat. You can never be paranoid enough. I back up anything of mine that is Bryce on two hard drives that are seperate from the hard drive that has Bryce installed on it, AND, I also make monthly back-ups to DVD. AS
AgentSmith ( ) posted Sat, 30 April 2005 at 11:04 PM ยท edited Sat, 30 April 2005 at 11:04 PM
*Note, when you use say a .jpg as a texture in Bryce, it will actually use it uncompressed...so, lets take a .jpg that is 800x600 and 300kb, in Bryce, uncompressed, it could swell up to 1.4 Megabytes.
Thus, a saved .mat, and/or a whole saved Scene file (.br5) will get much larger when using images as testures.
AS
Message edited on: 04/30/2005 23:04
zap326 ( ) posted Sun, 01 May 2005 at 12:04 AM
About the subject of exporting MATs out, then making new libraries without the 'bloat' of stuff that's not supposed to be there and should have been deleted....
That is, you delete an item from a library but it only deletes the thumbnail, not the actual library item itself.
Does the new version 5.5 of Bryce suffer from the same bug?
BTW, doesn't that bug exist for all the libraries not just the material presets?
It's a chore to carefully de-bloat my libraries, mainly the ones that get deletions a lot. To counter that I created various temp libraries so I could lessen the number of libraries to de-bloat, mainly when I'm testing and experimenting with MATs. - Works for me. :-)
AgentSmith ( ) posted Sun, 01 May 2005 at 2:03 AM
"Does the new version 5.5 of Bryce suffer from the same bug?" Let me play around with that and find out, I don't remember trying it out before. AS
Zhann ( ) posted Sun, 01 May 2005 at 3:38 AM
I have 'blank' presets for materials, objects, skies on my site under downloads 'Bryce'.............
Bryce Forum Coordinator....
FranOnTheEdge ( ) posted Sun, 01 May 2005 at 3:45 AM
So do I follow your saving method AS, (ie from inside Bryce, not from Win Explorer) when I want to save what I've accumulated in Bryce 4, so that I can add it to Bryce 5? (and will the same apply to getting stuff from Bryce 5 to Bryce 5.5 - if I ever manage to download it at all?) BTW, I'm more likely to want to save the entire user file/s, rather than just parts... does that make a difference?
Fran's Freestuff
AgentSmith ( ) posted Sun, 01 May 2005 at 4:34 AM
Oh, yes. Bryce 4 mats are absolutely importable into Bryce 5, no problem. And, yes the same thing from Bryce 5 to Bryce 5.5, yet if I remember right, you can ALSO go from B5.5 back to B5 if you want, the presets are cross compatible. Parts - Entire user file, imo. For (a Bryce 5.0) instance I will go to "Metal" catagory, select what ones I want, and all those will exported as ONE single .mat file, which holds all the various metal .mats (kinda confusing, but it works, trust me) AS
FranOnTheEdge ( ) posted Sun, 01 May 2005 at 4:35 AM ยท edited Sun, 01 May 2005 at 4:40 AM
pakled,
"import"? but that means I have to do it one at a time - it'll take forever! Isn't there any other way? WAIT... wait, oh, I see. You've first saved everything as a directory like "User" or "Metals" - THEN you "import" the whole shebang. Coool.
Message edited on: 05/01/2005 04:40
Fran's Freestuff
AgentSmith ( ) posted Sun, 01 May 2005 at 4:40 AM
My saving area, outside of the Bryce program directory, looks like this in Explorer. Inside the "Metal.mat" file is around 275 individual textures. AS
AgentSmith ( ) posted Sun, 01 May 2005 at 4:42 AM
X-post. Yeah, you understand it. ;o) AS
FranOnTheEdge ( ) posted Sun, 01 May 2005 at 4:48 AM ยท edited Sun, 01 May 2005 at 4:49 AM
Firefly? Planets? X-RAY STUFF!!! CoooOool! Hey, sounds like you've got some interesting stuff in there!
And "Saved Scenes" - how terribly organised of you. Mine in comparrison looks a mess.
It's a pity one couldn't have sub directories inside a directory like inside "Metals" it would be nice to have, say... "Rusty" "Corroded" "smooth" "new" "old" "Space-ship" "Floors".... oooh, things like that.
(still wondering what beautiful materials are inside "Firefly")
Message edited on: 05/01/2005 04:49
Fran's Freestuff
Yeah, I wondered why my edit took so long to upload.
Fran's Freestuff
AgentSmith ( ) posted Sun, 01 May 2005 at 5:09 AM
Firefly...lol. I found a Bryce DTE mat on a personal website one day that simulated a furiously flapping insect (moth, firefly, etc) I went to download it, and the link was broken. I tried back later, again, and again, and again, no luck. I wanted the ^%$! .mat! I e-mailed the author, no luck. I gave up. One day....MONTHS later, I ran across the link, tried it and it worked. I worked so hard to get it, it got its own personal folder, lol. AS
AgentSmith ( ) posted Sun, 01 May 2005 at 5:13 AM
"It's a pity one couldn't have sub directories inside a directory like inside "Metals" With Bryce 5.5 you CAN have that. Now you can't export a single master catagory, and have all those sub-catogories export along with it, But bryce 5.5 does have better organizing with its library presets. AS
FranOnTheEdge ( ) posted Sun, 01 May 2005 at 5:14 AM
yeah, you don't want to lose it now, huh? Um... any chance it might be shareable? (licking lips hopefully)
Fran's Freestuff
AgentSmith ( ) posted Sun, 01 May 2005 at 5:15 AM
Sure, it IS a free mat, I just can't get ahold of the author. hold on.
AgentSmith ( ) posted Sun, 01 May 2005 at 5:17 AM
FranOnTheEdge ( ) posted Sun, 01 May 2005 at 5:17 AM
OooooOOOOoooo, nice B5.5! And it looks a bit less busy on the daz site - so far. I've actually managed to start one of the downloads. Now if only we don't have another powercut today. Had one yesterday, right in the middle of the first attempt, then Daz got too busy to let me in, and the next 5 attempts just got that "page unavailable" thingie. Gosh, if you knew how envious I've been of those people who were complaining about b5.5 - I mean! They'd managed to actually GET it!
Fran's Freestuff
FranOnTheEdge ( ) posted Sun, 01 May 2005 at 5:19 AM
Arrrghhhh! I'm downloading from Daz!!! (looking hungrily at the buzzing firefly) Now I'll have to wait... (that's just not part of my nature you know) Thanks for the link AS, much appreciated.
Fran's Freestuff
AgentSmith ( ) posted Sun, 01 May 2005 at 5:22 AM
The link is in the backroom, so it's going NOWHERE, lol... AS
FranOnTheEdge ( ) posted Sun, 01 May 2005 at 6:39 AM ยท edited Sun, 01 May 2005 at 6:39 AM
Got it. Hopefully, I've also (finally) managed to download Br5.5 as well.
Today had been a GOOD day!
Message edited on: 05/01/2005 06:39
Fran's Freestuff
pakled ( ) posted Sun, 01 May 2005 at 7:55 AM
uh...FranOnTheEdge, actually I do do them one at a time, into the 'mat' file or category. If there's a faster way to do that, let me know. Ordinarily it's just something you have to do once..personal preference, etc. And they're right..once you add them to the 'category', they don't seem to go away. I've had a 'category' of 20 meg with no (remaining) mats in it.
