Fri, Nov 15, 5:40 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
Subject: Poser 6 render problems Please help me
peevee ( ) posted Mon, 02 May 2005 at 3:17 PM · edited Fri, 15 November 2024 at 5:39 PM
Any time I try a render in Poser 6 it fails: I always get the message that I can reduce render memory by reducing the bucketsize, ( currently put it on two ) reducing the maximum texture size ( 512 at the moment ) and turning of texture filtering ( and it is off ) my render dimension is about 40 cm by 30. The scene I want to render features Jessi ( and only Jessi ). So i wouldn't think that would jam poser 6 up... Please look in to this and find a solution for me... Working in Poser without being able to render is NOT fun Thanks a lot Peevee
thefixer ( ) posted Mon, 02 May 2005 at 4:13 PM
Peevee, quite a lot of us are having this problem and we're all waiting for CL to fix it. You'll just have to hang in there with the rest of us.
Injustice will be avenged.
Cofiwch Dryweryn.
peevee ( ) posted Mon, 02 May 2005 at 4:37 PM
Althow you may think I'm disappointed with this answer I'm actually over the moon!! I thought I had a malfunctioning version you see... Thanks for the info ! Peevee
svdl ( ) posted Mon, 02 May 2005 at 5:43 PM
40cm x 30cm - what are your DPI settings? It's the pixel dimensions that count. If you render at 300 DPI, 40cm x 30cm would be roughly like 16 inch x 12 inch, that means about 4800 x 3600 pixels. Which is BIG.
My gallery   My freestuff
thefixer ( ) posted Tue, 03 May 2005 at 2:29 AM
Nice point Steven, hadn't noticed that bit! Duh!
Cofiwch Dryweryn.
