Tue, Feb 4, 8:18 AM CST
Subject: Camera gone wonky - Help!
FranOnTheEdge ( ) posted Mon, 02 May 2005 at 12:15 PM ยท edited Tue, 04 February 2025 at 8:16 AM
Help! My camera has gone all wonky, dunno how or why. But how can I correct it without having to reset all the camera views? Fran
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
shinyary2 ( ) posted Mon, 02 May 2005 at 12:37 PM
Got an idea for you. Try turning PanV and PanH to 0, this seems to be what's causing it. Now you can just rotate and place your camera normally. Hope this helps.
FranOnTheEdge ( ) posted Mon, 02 May 2005 at 3:45 PM
Thanks, that worked great. I hoped that posting the camera's atributes might help - seems you figured that one out just great.
Fran's Freestuff
shinyary2 ( ) posted Mon, 02 May 2005 at 4:16 PM
Just out of curiosity, how did you end up with those values changed in the first place? Seems like I don't ever end up with anything other than zero in there.
FranOnTheEdge ( ) posted Mon, 02 May 2005 at 5:46 PM
Um... I have absolutely no idea. Probably something to do with me thinking I'm in "From Left" or "From Front" or something like that and using the plus sign &/or the minus sign just above the little hand on the bottom right... that's all I can think I could be. (shrug)
Fran's Freestuff
shinyary2 ( ) posted Mon, 02 May 2005 at 6:02 PM
hmm that makes sense. If you are using the camera (and not director's), you know you can use ctrl-Z to get the camera back where you want it. That what I usually do when I make that mistake (which happens ALL the time for me, usually at around 1a.m. lol). Cheers
jedswindells ( ) posted Mon, 02 May 2005 at 6:35 PM
Make use of the camera memory dots,then you can easily nip back to where you were!
FranOnTheEdge ( ) posted Mon, 02 May 2005 at 6:47 PM
I do try to remember the camera dots... not used to using them much - yet! But it is very handy so I expect to get better at remembering to use them. Hopefully....
Fran's Freestuff
