Sat, Feb 8, 2:22 PM CST
Subject: *** vue 5 infinite & poser 5 ***
pacman323 ( ) posted Wed, 04 May 2005 at 1:53 PM ยท edited Wed, 22 January 2025 at 3:58 PM
hi all i have V5I and poser 5 recently i have make a scene with poser 5 the size is 165 mo :p and i want to import this scene in V5I my computer is a P4 3ghz with 1go ram my graphic card is fx 6800 256mo and V5I don't want to imported it too large. I would like to know if there is a solution for this --did a must to cut my composotion in several part and imported them in V5I -- or there is another solution please help me thx to you Manu
lanaloe77 ( ) posted Wed, 04 May 2005 at 2:03 PM
I am just guessing but maybe you can break up the scene into multiple poser imports. Then import each poser object into a blank vue scene. Then save the imports (after adjusting the materials)into vobs. Repeat the process for all the poser imports. Then when you are done import all the vobs into your main scene.
ShawnDriscoll ( ) posted Wed, 04 May 2005 at 2:03 PM
Why only 1GB RAM on your system? Add 1GB more.
agiel ( ) posted Wed, 04 May 2005 at 2:32 PM
Since you have Vue Infinite, there is one more step you should consider when saving and importing poser objects separately : - load your poser objects one at a time - use Bake to Polygons to turn your objects into a single 3D mesh - then use Decimate (ouble click on the object to bring up the option). This will allow you to reduce the number of polygons in that object. I recently imported a 3D polygonal curved mesh from Amapi into Vue. The original object was 56 M. After Bake to Polygon and Decimate, the saved VOB object was only 8 M. It is well worth a try !
lanaloe77 ( ) posted Wed, 04 May 2005 at 3:41 PM
wow, nice reduction. How long did it take to bake and decimate that particular mesh?
agiel ( ) posted Wed, 04 May 2005 at 5:48 PM
About 1 hour overall... I had to try a few times bcause I was flirting with the limits of my memory and Vue kept crashing. One more trick - set the number of Undo to 1 or 2 - you will save a lot of memory that way.
ignition ( ) posted Sat, 07 May 2005 at 1:31 PM
Hi, From my limited experience ... and what I've read on the E-On forums ... Vue 5i seems to have a problem with large texture maps. Try reducing the textures to 1000 pixels in the largest dimension. I know this is a pain, because it means saving a new, lo-res version of all of your Poser textures and then reapplying them, but it will reduce the file sizes and make Vue much happier. Also try using one of the morph management tools to get rid of morphs you are not using. There are good tutorials at daz3d.com about morph management. I doubt it is the polygon count of the models. Good luck. - Dave B.
