Mon, Feb 10, 6:29 PM CST
Subject: Space Scenes
zorares ( ) posted Wed, 04 May 2005 at 9:19 PM ยท edited Sat, 01 February 2025 at 5:52 AM
Is is possible to make a planetary space scene in Vue? I know that it can be done in Bryce but I sure can't figure out how to do it in Vue.
http://schuetzenpowder.com/sigs.jpg
agiel ( ) posted Wed, 04 May 2005 at 9:44 PM
You mean something like this ?
zorares ( ) posted Wed, 04 May 2005 at 9:53 PM
EXACTLY! How'd you do that?
agiel ( ) posted Wed, 04 May 2005 at 10:39 PM
- open a new scene - select Atmopsheres -> Effects -> Other -> Outer Space - Add a sphere to the scene - Edit the material of the sphere with a texture map from a planet (you can also simply use a Vue Planet). You also have links in the Backroom, under Materials, to download texture maps of planets. - Add a spaceship and you are done :) Here is a wide shot of the planet, a simple sphere with a Mars texture map.
zorares ( ) posted Wed, 04 May 2005 at 11:41 PM
pesuchet ( ) posted Thu, 05 May 2005 at 11:58 AM
excuse me agiel, but where in V5I you select ? - select Atmopsheres -> Effects -> Other -> Outer Space thanks
spedler ( ) posted Thu, 05 May 2005 at 3:10 PM
but where in V5I you select ? - select Atmopsheres -> Effects -> Other -> Outer Space Atmosphere menu, Load Atmosphere, open the Effects collection, within that is the Others collection, where you find Outer Space in the third row down in the middle (at least, it is on my system!)
Steve
zorares ( ) posted Thu, 05 May 2005 at 3:11 PM
Don't forget to delete the ground.
