It's PSP. It's not using standard file formats. Been there done that. You could use Xnview to convert the images. It's probably saving thumbnails along with the image. I think you can turn that off though. I do the select all instead. Um the default image size is not set big enough for the paste. It's not photoshop. Open new, check the default size. Make it bigger before you do the paste.
![file_235649.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_235649.jpg)
Rendered in V5I(latest release). Saved as .tiff. I opened in Paint Program & when I say load selection it does NOT select the whole image :(. This has not happened prior to this release. Is this a bug??? Sorry for the size of the image but wanted to show the selection & the paste. TIA
