Wed, Feb 5, 8:19 AM CST
Subject: Ok, next 5.5 question
Claymor ( ) posted Sun, 08 May 2005 at 3:14 PM ยท edited Tue, 28 January 2025 at 5:19 PM
Sorry if this one has been answered.
I am trying to use a black and white image to create a terrain, copying the image to clipboard out of photoshop and pasting in the "image" tab in terrains. The original image is a square. I started out at 750 x 750 then tried 500 x 500 and even went down to 250 x 250....every time I paste it does some odd, off center, tiling thing.
Is there some new default setting I am missing?
This is useless to me if I can't get the image to paste correctly.
Claymor ( ) posted Sun, 08 May 2005 at 3:30 PM
Ok, some follow up... I copied out of photoshop and pasted in Microsfot Image composer...pasted as I expected it to, just fine. Copied out of Image Composer into 5.5 and it worked fine. Possibly a problem reading the clipboard from photoshop?
Incarnadine ( ) posted Sun, 08 May 2005 at 8:21 PM
Try saving it and then open from the saved image.
Claymor ( ) posted Sun, 08 May 2005 at 8:56 PM
Yeah, there are several work arounds that might solve it...but it looks like a bug to me.
foleypro ( ) posted Sun, 08 May 2005 at 9:54 PM
Bug....
Erlik ( ) posted Mon, 09 May 2005 at 1:02 AM
Possibly. Original 600x600, this was pasted from Photoshop 7. Tried both pasting directly to Terrain Canvas and to the image tab.
-- erlik
AgentSmith ( ) posted Mon, 09 May 2005 at 1:44 AM
I tried it to make sure. I have no problem copying out of Photoshop 7 or 8, and pasting into Bryce 5.5 In Photoshop, make sure you have a flattened image (or the layer active you wish to copy), and make sure you don't have any selections active. Also, Bryce ONLY uses images in the sizes 128, 256, 512, 1024, etc. Any other size image and it will be resampled/resized, thus the pixel clarity from Photoshop to Bryce could suffer. (not much, but when you are trying to make everything look as good as possible....) AgentSmith
Claymor ( ) posted Mon, 09 May 2005 at 9:18 AM
Huh...I'll try it again. Could it be that I am using the unpatched 5.5 and you guys are using the patched? I may have inadvertantly loaded up the wrong one. I've never seen the result I was getting ever in any combination from Bryce 4 and 5 and Photoshop 5 through 7. The result example I posted above is exactly what I got going from Photoshop to Bryce, the same clipboard pasted fine in MSIC.
AgentSmith ( ) posted Mon, 09 May 2005 at 5:35 PM
I'll try a pattern that looks similar to yours. Ya never know. AS
Claymor ( ) posted Mon, 09 May 2005 at 6:24 PM
I tried another pattern out of Photoshop and it worked fine. I tried copying this one to a new doc in Photoshop, then tried to C&P from there and it gave me the same error as above. Gave me the same error when trying to paste as a picture mat.
