Are you using high-quality textures? If so, sometimes Poser runs out of memory when loading these - try disabling bump maps or substituting the textures with some reduced-size ones (be sure to "save as", close poser and then re-open it with the new textures, however). Also, should you be using some old MAT files for P4, they sometimes load .bum files as bump maps, which are rather huge if hi-res (and AFAIK do nothing on P5) that can be removed at once.
Hi All I have a problem that Poser seems to freezer when I am rendering, when I turned 'Smooth Polygon' off and it seem to work okay? Is this normal, can I fix it, or am I doing something wrong. I have Poser 5, and this is the first time I have tried doing anything with 2 people so it is a little bit more complex then other renders. Thanks Grant
