From the FAQ: I can't export my object, the "Export Object" option is grayed out in my menu. *Bryce will not export out its primitives or metaballs. And, no, there is no 3D file converter for .obp's. *Bryce can export out its Terrains, and Lattices and rocks as a generic 3D file (3ds, dxf, x, id4, lws, mts, 16-bit pgm, rds, hf, cob, dem, vsa, wrl, obj, nff) *Bryce can export its Rocks as a generic 3D file (3ds, dxf, x, id4, lws, rds, cob, vsa, wrl, obj, nff) *Other Bryce properties can be exported out only in their native Bryce format (trees, skies, mats, obp's, texture files, etc) *Un-exportable items can be saved as a Bryce .obp (object preset), and saved/exported out (again, only as an .obp) *Generic mesh files that are previously imported into Bryce, can then be exported out as a generic 3D file. (formats are the same as Bryce Rock) This allows Bryce to be a quick and dirty 3D file converter if need be. See how to do this kind of exporting here.
Come visit us at RenderGods.
Ignore the shooty dog thing.
Attached Link: http://jmezon.blogspot.com
i use Bryce 5. my problem is that i can't EXPORT any object: i select the object [a tree], i go to File->Export Object, but i can't select this option [that is "blocked"]. what i have to do??? Thanx a lot for reading and for help!JMz
Message edited on: 05/04/2005 06:47
