Sun, Nov 24, 5:42 AM CST
Subject: Bryce 3D Crashes with ATI All-in Wonder Radeon
walleye0691 ( ) posted Sat, 03 February 2001 at 12:49 PM · edited Fri, 02 August 2024 at 7:17 AM
I just installed an ATI All-In Wonder Radeon (AIW Radeon). Everything seems to work fine except when I try to bring up Bryce 3D I get the following: Program performed an Illegal Operation and will be shut down BRYCE 3D caused an invalid page fault in module ATIO9XAG.DLL at 0187:690f420c. I have reloaded DX8 drivers with no luck. It wouldn't work with DX7 either. I also have Poser, which comes up fine. Any suggestions - ATI was no help at all! Rick
fozzibear ( ) posted Sat, 03 February 2001 at 2:38 PM
You might want to try http://support.atitech.ca/products/pc/radeon/radeon_drivers.html Hope it helps!
thuffner3 ( ) posted Sun, 04 February 2001 at 7:02 AM
Memory, I was having problems of the same type but with just a standard video card. I was forced to upgrade to a 7200 speed HD, Increase my memory, and ultimately replace my video card. I may be wrongm, but Bryce is a memory hungry program, which doesn't really use the capabilities of the high end video cards. So memorys got to be it.
walleye0691 ( ) posted Sun, 04 February 2001 at 10:57 AM
Thanks for the info. I'm already using a 7200rpm HD and have 256MB of Ram on an 850Mhz proocessor (PIII). I've reloaded Bryce and reapplied the upgrade to Bryce (including the preset upgrade). I suspect it may be a problem with the Radeon drivers which is why I'm trying to find anyone who is using an AIW Radeon with Bryce 3D successfully. Thanks again for trying, Rick
Quikp51 ( ) posted Sun, 04 February 2001 at 8:09 PM
3dfiles.com has just released on their page a utility to tweak Radeon based ati cards. Give it a look and see if it can help you.
