Wed, Feb 19, 12:42 AM CST
Forum Moderators: RedPhantom
Subject: How do i create Injection Pose for aiko 3.0?
Boomtrooper ( ) posted Mon, 16 May 2005 at 8:18 AM ยท edited Wed, 19 February 2025 at 12:39 AM
Hi, I have tried with very limited sucess to create injection poses for a caracter i made with aiko 3.0 but the only thing that works is the head morph i made with Injection pose builder.. I need help and a detailed tut with images..i know there is a way to do this since some people are actually doing it but i just need to be teached how. any suggestions or info is welcomed. thanks.
RHaseltine ( ) posted Mon, 16 May 2005 at 8:24 AM
Actually, since Aiko 3 has the morphs in the CR2 you don't need an injection pose as such. What should work is load the saved figure (CR2) file into Injection Pose Builder, select A3 as the figure type, disbable the Use Readscript option (since you aren't after an Inj pose) and hit process - most of the other options should be correct in their default state.
Boomtrooper ( ) posted Mon, 16 May 2005 at 10:56 AM
then how do i create a resellable caracter if i don't have inection morphs? I have set up a caracter by turning and tweaking dials and i want those settings to transfer to a base aiko 3 when the potential buyer wants it so what is the best "legal way" to do this.... thanks again...
RHaseltine ( ) posted Mon, 16 May 2005 at 2:59 PM
Ah - a confusion over terminology. Most of the current DAZ figures don't actually contain the deltas (the changes to the shape) for their morphs, they have to be read in (injected) from an external file. Aiko (and Hiro) already contain their morph deltas, so all you have to do is create a pose (usually called a Mor pose) to set the value of the morphs. You can use Injection Pose Builder for that - as I said, just turn off the Readscript functions (middle-right of the dialogue, as I recall) and try with everything else in the default state.
