Wed, Nov 27, 2:17 PM CST
Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
Subject: HELPPPPPPP
SoulSearcherr ( ) posted Mon, 16 May 2005 at 2:09 PM · edited Wed, 27 November 2024 at 2:16 PM
please look at the attached pic..it just started doing this today after I had already taken 100 that was perfect..anyone have any idea what is wrong with my canon..cryyyy
Michelle A. ( ) posted Mon, 16 May 2005 at 2:15 PM
Hmmmmm....??? We've established that it's a Canon camera....I'm assuming it's a digital..... now what kind of camera? A point and shoot? A compact zoom lens? A dslr? Did you use flash? It almost appears to be a shutter curtain/flash issue, but without knowing any other details, it's tough to say? And my question to the more knowledgable.... do digital camera's even have a shutter curtain?
I am, therefore I create.......
--- michelleamarante.com
SoulSearcherr ( ) posted Mon, 16 May 2005 at 2:20 PM
it is a digital rebel..and was not using flash..and was using at the time..75-300 canon lens
tibet2004uk ( ) posted Mon, 16 May 2005 at 2:44 PM
I don't even know what a shutter curtain is Chelle! ashamed Care to explain while u're at it!? wink ;D
Michelle A. ( ) posted Mon, 16 May 2005 at 3:12 PM
Quick pic of a shutter curtain in a 35mm camera....... When you snap the shutter, the lens aperture opens and the shutter curtain slides open to expose the film and then is slides closed. When using the wrong flash synch mode you will sometimes see an image much like the one above, half exposed/ half unexposed..... because the shutter curtain didn't open in synch with the flash settings.....
L8RDAZE ( ) posted Mon, 16 May 2005 at 3:20 PM
Did it happen on just this one image or is it happening on all thatyou take?!?!? That info may help troubleshoot! BTW...My Canon G6 has a setting for 1st and 2nd curtain (which I have yet to explore!)
SoulSearcherr ( ) posted Mon, 16 May 2005 at 3:22 PM
my last 24 shots..same as this one..
L8RDAZE ( ) posted Mon, 16 May 2005 at 3:23 PM
Attached Link: http://forums.dpreview.com/forums/read.asp?forum=1031&message=13346929
Found this...about the REBELS flash synch speed!
Onslow ( ) posted Mon, 16 May 2005 at 3:25 PM
Have to agree with Michelle looks like a shutter problem. There are 2 curtains and they work by exposing a strip of light across the sensor - it does not look like the sync is right and therefore the strip of light is not travelling the full sensor height.
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies live;
Their heads are green, and their hands are blue, And they went to sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
SoulSearcherr ( ) posted Mon, 16 May 2005 at 3:31 PM
still not working
Onslow ( ) posted Mon, 16 May 2005 at 3:54 PM
:( so sorry......... It is going to be something to be fixed by a Canon repair specialist.
Edward Lear
tibet2004uk ( ) posted Mon, 16 May 2005 at 4:03 PM
Ooooh! Thx Chelle! I don't think I have that on my cam! Too basic I guess! :( depressed
jimry ( ) posted Mon, 16 May 2005 at 4:46 PM
Ok...MIGHT have solved the prob...? I have a Canon ID Mk ii as most know..no built in flash!...the highest my flash synchs is 1/250th with the Canon dedicated BUT you need to INPUT that on the flash itself...just a thought:) BUT it does seem that the synch is wrong somewhat on the Rebel...what is the highest it can sycnh at?
jimry ( ) posted Mon, 16 May 2005 at 4:47 PM
whops... yeah...the rebel synchs at 1/200th
Michelle A. ( ) posted Mon, 16 May 2005 at 4:48 PM
Yes but if flash isn't being used???? Which is what SoulSearcher said.... no flash...... Strange.....
jimry ( ) posted Mon, 16 May 2005 at 4:52 PM
this is the kind of effect you get with second shutter curtain...
jimry ( ) posted Mon, 16 May 2005 at 4:57 PM
EEEk,...yes,...no flash....certainly a curtain prob...cannot see what else it could be cept that. Ok...what where the setting you used?...may seem trivial but might help? Maybe the card is corrupted?
jimry ( ) posted Mon, 16 May 2005 at 4:58 PM
RAW, JPG?...auto, manual, aperture, shutter pri, ?
SoulSearcherr ( ) posted Mon, 16 May 2005 at 9:39 PM
sorry for taking so long..it was jpg..auto..no flash..but I tried manual and that same thing happened..and I tried another card and another lens
coolj001 ( ) posted Tue, 17 May 2005 at 8:18 PM
Sorry to hear about that. I hope you get the issue resolved soon... -Jeff :-)
