Two important steps: 1) Where is the magnet base? 2) Have you CALIBRATED the magnet base? I always place my base, then calibrate it by making its scale 100%, then make the base and mag itself Invisible, then position and tweak the mag zone. Then I start adjusting the invis mag til I get the desired results. The calibration step is something I had never heard of before I read a Doc Geep tutorial, but Ive never had a magnet fail to effect the surface I was working on since doing this. Oh also, VERY important, make sure you did spawn the magnet from the correct object/body part you want to effect. Ive not paid attention and discovered I had spawned with the wrong area selected before. Hope this helps, Logan
Still no luck. The zone isn't misplaced because I move it all around the object and try morphing and still nothing happens. It's not like I have no idea how they work...they just don't sometimes and I can't figure out what I'm doing differently from when they work the way they're supposed to. Calibration's not it, nor is too few polygons since I've had them work and then not work ON THE SAME FRIGGIN OBJECT ON THE SAME SPOT! I'm wondering if it's a bug or something. Anyone ever had the same problem before?
Ok, half the time when I use magnets I put the zone where I want and then move the mag around until I do whatever it is I want to do. Half the time, I do all that and... nothing. Nothing happens. No deformation. WTF? Am I missing something?
