Thu, Nov 28, 8:38 AM CST
Subject: Poser 6 texture questions
Rita ( ) posted Tue, 17 May 2005 at 5:46 AM · edited Thu, 28 November 2024 at 6:50 AM
#1: When I use Poser4, I can easily apply a texture of mine to a primitive. How do I do so with P6? #2: In p6 how do I retrieve a node that is hidden to the far right side? See attached.
maxxxmodelz ( ) posted Tue, 17 May 2005 at 5:51 AM
If it's a texture map, simply attach a 2D image_map node to the diffuse channel. To retrieve those hidden nodes, just use the scroll bar at the bottom of the material room window. It's that silver slide bar directly underneath your poser surface preview. There's another to the right of the window next to the Wacros buttons for scrolling up and down too.
ziggie ( ) posted Tue, 17 May 2005 at 6:00 AM
Oh blech..! I was just reading this thread and actually tried to move the slider bar in the image above wif my mouse. Doh..!
"You don't have to be mad to use Poser... but it helps"
Rita ( ) posted Tue, 17 May 2005 at 6:32 AM
Thanks!!!!!!!!!!!!!!!
maxxxmodelz ( ) posted Tue, 17 May 2005 at 6:44 AM
LMAO @ ziggie!! That's funny. Rita, you might also want to check out the "simple" version of the material room. Coming from P4, you might find it easier to use until you can familiarize yourself with the advanced version (nodes). Just click on the tab that says "Simple" in the material room at the top left. See if that's not easier for you. Good luck.
Rita ( ) posted Tue, 17 May 2005 at 2:04 PM
I'm getting the hang of the nodes so thanks!!!!!!
