Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 9:02 am)
Attached Link: Embedding New Morphs inside Pose Files by DraX
The easy (for you) way is to export the morph as Wavefront Object file, this should work in any version of Posre with any figure.The basic procedure is to load the morph into your figure, zero any other morphs in that actor (body part), from the Posre menu barthen do; Figure > Export > Wavefront OBJ >, click OK in 'Export Range' box > un-X 'UNIVERSE' in 'Hierachy Selection' and place an 'X' in the relivent actor, then click 'OK'. Give the file a discriptive name (eg Mellons.obj), tick (check) only 'As Morph Target' in the 'Export Options'.
Next you need to open the resulting obj file in a text editor and delete all lines that do not start with 'v ' (v space). This does two things, it significantly decreases the size of the file, and it removes data that could allow someone to recreate the original body part from which the morph was made (which is usually copyrighted).
Another option (easier for the end user) is to make a Delta Injection pz2 (pose) file, a lot has been said on this subject, for an introduction see the URLs below, also do a search in this or the 'Poser Technical' forum for 'Delta Injection' and 'INJ'.
http://www.renderosity.com/messages.ez?Form.ShowMessage=394068
http://www.renderosity.com/messages.ez?Form.ShowMessage=2182046
http://www.renderosity.com/messages.ez?Form.ShowMessage=1803137
I am just starting to play with magnets to make my own morphs for various figures. Some of the morphs I think others might like to use too, but I don't understand how to export or share them. I can save the magnets in my props folder to reapply to figures myself, and I can spawn a morph target and then save the new figure (generating a .crz file on my drive) to reload later. But what is the best way to export the new morph target for easy transfer to someone else to use on the same base figure on their computer? And how would they actually load it? Many thanks for the guidance!
