Thu, Feb 13, 8:37 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Subject: Does this happen to anyone? (memory bug?)
Talos ( ) posted Wed, 18 May 2005 at 1:22 AM ยท edited Thu, 13 February 2025 at 8:23 AM
I will be retexturing a rather simple Victoria 2 (not even 3) figure (alone in a void, not even a scene), then do something as trivial as selecting a new eyebrow transparency when Poser 6 will ask me if I want to save the scene first (I think "Huh? Why? What?"), then the whole thing locks up, and I have to hit control/alt/delete to get out of the program and lose everything. Anything to do with the famous memory bug? I never got this in Poser 4. I guess it's a new case for "save early, save often".
DIMENSION_X ( ) posted Wed, 18 May 2005 at 6:24 AM
This is happening to me and a number of other artists with varying problems. This has been extensively documented on the forum's here. CL are in process of releasing SR1 update to resolve this issue
ggtonet ( ) posted Wed, 18 May 2005 at 6:26 AM
I had a similar problem in P4, maybe there's an imported figure that is corrupted...
jacksilverburgh ( ) posted Thu, 19 May 2005 at 4:44 AM
I had this problem with simple scene with V3. I wanted to save and some message showed up telling me I have to save,cause memory. So I did, but saved file was empty (0kb). I found out that Opera 8 was causing the problem. When it was shut down, Poser went ok even with the same scene...
