Tue, Nov 19, 5:17 PM CST
Subject: Tatooing again, again and again...
Pax_Corpus ( ) posted Fri, 07 February 2003 at 8:45 PM ยท edited Tue, 19 November 2024 at 2:52 PM
OK! I tatooed the girl. I just got one problem with the skin colour turning brighter after applying the tatoo. I follow the tutor by quinlor, but still I got this problem. I manage to bright up the head color on the girl, but on the man I didnt do anything with head texture. Look at the difference. Thanx for any help. /Pax Corpus Girl: http://home.no.net/corpus/photo/motorpsycho%20girl.jpg Man: http://home.no.net/corpus/imgs/tatoo.jpg
pdxjims ( ) posted Fri, 07 February 2003 at 10:31 PM
Here's a screenshot of a simpler way than posted earlier. The screenshot is hard to read, so here's a step by step instruction list. 1: Load your texture 2: Go into the material room and disconnect the texture from the Diffuse setting. 3: Create a new node off the diffuse setting for Color_Math (not off of the alternate diffuse setting). Make sure the color for both value 1 and value 2 of the Color_Math are set to white 4: Attach Value1 to the texture 5: Create a new 2D texture node off of Value2 (image_map) 6: Load your tattoo into this. Set the image mapped parameter for this to None (default is tiled). Size your tattoo using the U_Scale and V_Scale parameters. Position it using the U_Offset and V_Offset parameters. Set the strength of the texture too. Real tats aren't solid after the first day, they all fade a little. I usually use .7. You're done.
pdxjims ( ) posted Fri, 07 February 2003 at 10:35 PM
Here's the render. The earlier example was off of the alternate diffuse and included the skin node. Niether is needed for a simple tat blend. Other nodes can still be played with. You can even change the colors on the Color_Math, just make sure value 1 and value 2 are the same.
pdxjims ( ) posted Fri, 07 February 2003 at 10:36 PM
Yikes! The color math setting needs to be "Multiply"!
Pax_Corpus ( ) posted Sat, 08 February 2003 at 7:59 AM
Hey! Thanx for that!
akura_ ( ) posted Wed, 18 May 2005 at 10:35 AM
Does it only suppose to show when you render it?
pdxjims ( ) posted Wed, 18 May 2005 at 10:46 AM
It only shows when you render in P5. I don't know how it'll show in P6.
akura_ ( ) posted Wed, 18 May 2005 at 10:49 AM
Ok, few, I thought I did something wrong them. Im using Poser 6, does that matter.
