Mon, Jan 27, 9:40 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Subject: Another "newbie" here....
Rose ( ) posted Sun, 04 February 2001 at 10:37 PM · edited Sun, 26 January 2025 at 8:46 PM
Attached Link: http://members.aol.com/Roseb44170/graphics.htm
Okay, first let me say "Thank You" to whoever created this program! Just because I haven't mastered it yet doesn't mean that its not a great program. Now with that being said - "I DON'T GET IT" - to coin a phrase - ARGHHHHHHHHHHHHHHHHHH! I understand the process of loading a .obj into UV Mapper and then saving it both as the .bmp and as a new object. My problem comes after I color in the .bmp. I save it then I go to Bryce. I guess I should preface this by saying that first of all I'm wondering if anybody is using the same programs as I - ie Bryce, Rhino and Blender. Since I have trouble importing objects into Bryce I use "Crossroads" to convert my .obj into .dxf so that I can load it onto Bryce. My problem comes when I try to add the 2D texture to my newly created .obj (which is now a .dxf object). The 2D renders as pieces - not a completely filled texture. So first I ask will UV Mapper work if you convert the newly created .obj to another format? And 2nd is there something that I am doing wrong (or don't have the right settings set)so that the .bmp texture I created will map on the object without so many gaps? I humbly bow to your expertise!
ninhalo5 ( ) posted Mon, 05 February 2001 at 12:14 AM
i may be wrong but generally the tex map looks for the original *.obj file that you save it as in poser i myself have never had much luck adding maps to *.dxf files which are used mostly for blueprints hence no maps... but what type of problems are you having with importing *.obj files into bryce? generally it's a fairly easy process but sometimes it may take a long time to import. all depending on the size and quality of an obj file. by the way welcome to the big artist family jeff
Kurka ( ) posted Mon, 05 February 2001 at 12:16 AM
Why don't you just load the OBJ file into Bryce? It should load without any problems. Also, there's no need to create a new UV map for an object created in Poser. If the OBJ format gives you trouble, try 3ds. Also, if you need to convert formats, use 3D Explorer, available at: http://www.xdsoft.com works much better. Which version of Bryce and Poser are you using?
Lorraine ( ) posted Mon, 05 February 2001 at 8:28 AM
Just export from poser4 to object file, click on the box that says retain names of groups, then name your object. Open bryce 4 then import the object you just named. Except for the transparancies everything should be mapped properly when it comes into bryce. Just go to materials and diddle with the transparancy. A bit of warning, position the whole object before you ungroup for the texture diddling. I have trouble sometimes if I ungroup then try to move the figure, but that is just me I am not nearly as proficient as I want to be with either of these programs....but I am having fun. ...keep saying to yourself ...I am a human being...human beings created this program, therefore I am capable of mastering the program...I am in charge...I command you (insert name of program) to do as I say.... It is not listed in the manual anywhere but I find that this makes ME feel more powerful....however sometimes I get the distinct impression that these programs giggle ...but then hours in front of my computer can make me hear things.... :-)....
