Wed, Nov 27, 6:35 PM CST
Subject: Posing tutorials
MoonFlower ( ) posted Fri, 20 May 2005 at 3:36 PM · edited Wed, 27 November 2024 at 4:45 PM
can i please have some posing tutorial links? i really want this pose and i haven't been able to find it i surely don't know how pose but i'm really willing to learn. :) p.s. i would like the tutorials with lots of pics in them. ;)
Message edited on: 05/20/2005 15:38
Fazzel ( ) posted Fri, 20 May 2005 at 3:49 PM
What I do when I want to pose something and there isn't a canned pose for it is to just take something that is close to the pose I want and then just start spinning the dials. It takes a while, but like anything, the more you practice at it the easier it gets. This one for example, could start as a kneeling pose, which there are lots of in the Free Stuff section, and then just move things around to make it look more like this. Turning IK on and off for the hands will let you get the hands just where you want them.
MoonFlower ( ) posted Fri, 20 May 2005 at 4:01 PM
ik?
Tunesy ( ) posted Fri, 20 May 2005 at 4:40 PM · edited Fri, 20 May 2005 at 4:42 PM
I don't know what the gurus do, but here's what I do when creating a pose from scratch in most cases (not all):
1--Adjust the hip rots as best you can.
2--Adjust the butt and ab dials. (Ignore the rest for the time being. You can hide parts if you like, but I don't bother with that.)
3--Go back and fine tune the hip rots now that the butt and ab dials have been approximated.
4Now fine tune your butt and ab dials to compensate for your corrected hip adjustments. (At this point you are done with adjusting the hip, hopefully ;)
5Moving farther outward from the root (hip) its time to adjust the chest and thigh dials and so on and so forth.
Basically, youre working from the root (hip) outward. I used to get fouled up by doing outer parts prematurely causing me to do more dial spinning than necessary. This little process has saved me a lot of time and its really quite simple. I hope I didnt word it awkwardly. Thanks for asking this question here. Im interested to see others thoughts on this as well.
Message edited on: 05/20/2005 16:42
Acadia ( ) posted Fri, 20 May 2005 at 5:11 PM · edited Fri, 20 May 2005 at 5:21 PM
Attached Link: http://schlabber.org/html/tut00.htm
Hmmm, doesn't Schlabber have some tutorials on posing at his site? I remember coming across some posing tutorials when I was just starting out in Poser, and while I'm not 100% sure, I think it was him.
I'll have to try and find the link because I think I'm at a point now where I actually feel I'll benefit from the tutorials. I'm wanting to tweak poses more and more and the various parts of the figure and what to move or not to get what I want is confusing. I relate to moving body parts by "joint", but in poser it's literally by body part and not joint. That throws me for a loop, hehe
EDIT: yep. It was him.
Message edited on: 05/20/2005 17:21
Tunesy ( ) posted Fri, 20 May 2005 at 5:42 PM
Using the method I (The Talentless One) outlined above it took me 6 minutes to come up with this approximation of your pose.
MoonFlower ( ) posted Fri, 20 May 2005 at 5:59 PM
yeah! that's the pose except for the right leg should go under. i need a tutorial with pictures!!!
Tunesy ( ) posted Fri, 20 May 2005 at 6:12 PM
I noticed the 'right leg thing' and here's my take on it, but I'm no artist. If you look at your sketch you'll see that it looks like the right thigh is facing out and a bit left/down from the viewer. The shin is bent about 90 degrees or so. It seems like the foot should be at least partially visible, but, I dunno ;) Maybe I'm wrong. In any case that's a detail that's easy to adjust.
KarenJ ( ) posted Fri, 20 May 2005 at 6:18 PM
Attached Link: http://www.e-frontier.com/article/articleview/1010/1/319/
Stefan (Schlabber) has a tutorial on posing hosted at Curious Labs, which should give you an idea how useful it is :o) It's a .pdf download file and it's really extensive and has a lot of pictures. Give it a try!
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
Tunesy ( ) posted Fri, 20 May 2005 at 6:41 PM
I second Karens suggestion. I read everything I could find posted by Schlabber before my copy of Poser had even been delivered)) Been a while, so, frankly, I had forgotten.
Tunesy ( ) posted Fri, 20 May 2005 at 7:43 PM
...disregard my assessment of the 'right leg thing' above. Told ya I wasn't an artist ;) The subject is, presumably, sitting on a flat surface in your sketch. In my quicky pose I paid no attention to that. The subjects foot would be sticking through the floor. Easy to fix though. I also paid no attention to horizontal torso and head orientation, not to mention the chin needs to come down a lot (with both head and neck adjustments, I think). Point is, the method works well, but a mere hobbyist like me will take an hour to see what an artist will see instantly. I'd guess that fine tuning the pose would add 2 or 3 minutes to the process, but the talented would see the need much faster than I would.
MoonFlower ( ) posted Sat, 21 May 2005 at 5:27 AM
Thnx guys i shall try all of ur suggestions. I WILL LEARN TO POSE COME HELL OR HIGH WATER! :D Tunnesy, Acadia, Fazzle and Karen u rule! :)
JHoagland ( ) posted Sun, 22 May 2005 at 2:40 PM
Attached Link: http://www.vanishingpoint.biz//tutorials.asp
We have a Super-hero Posing Tutorial at Vanishing Point. I know it's not a pin-up pose, but it should help you with some of the fundamentals of creating poses from reference images. --John
VanishingPoint... Advanced 3D Modeling Solutions
