Thu, Nov 7, 2:29 PM CST
Bryce F.A.Q (Last Updated: 2024 Oct 30 3:44 am)
Subject: Mixing Materials
sittingblue ( ) posted Sat, 21 May 2005 at 5:21 PM · edited Sun, 15 September 2024 at 11:50 PM
Can Bryce mix materials like Vue can? For example, the user would use a material map that splits one material into two materials.
  • Charles
Charles
Rayraz ( ) posted Sat, 21 May 2005 at 5:28 PM
you can build textures from up to 4 components. Bryce doesn't have a node-based texture system like mojoworld (and VueInfinite too probably?) have.
(_/)
lordstormdragon ( ) posted Sat, 21 May 2005 at 5:42 PM
So in this manner, the answer is yes, it can mix up to four materials. If they are all procedurals, they will have three "inputs" apiece, so a total of 12 different inputs... Usually it's enough to get the procedural job done, although there are some limitations the only real limitation is your patience and imagination...
ysvry ( ) posted Sat, 21 May 2005 at 7:07 PM
hes asking for the three button solution were a and b materials are mixed acording to the greyscale in c.
for some free stuff i made
and for almost daily fotos
Zhann ( ) posted Sun, 22 May 2005 at 1:12 AM · edited Sun, 22 May 2005 at 1:13 AM
But Bryce will not 'split' one material into two separate mats unless, the one was comprised of 2-3 channels to begin with, you can make one mat by using two different channels.
Message edited on: 05/22/2005 01:13
Bryce Forum Coordinator....
