Check the "Hither" setting on the camera. It causes items that are too close to the camera to be invisible. That could cause what you are seeing there. EDIT: I had to adjust the brightness on my monitor to see a little better. Now, looking at it more closely I'm not so sure it's the hither setting, but it wouldn't hurt to try it.
Message edited on: 05/24/2005 18:49
Parameter box>Camera>Shadowcam is the P5 filepath. P6 does not show a shadowcam view at least not on mine. I depend on it and use it on every render I do. Only way to know where the shadows fall... I did import a P5 shadowcam set but did not get a "view" on those either (distorted low focal view) in P6. Looks like I've got some things to work around.
OK...I imported my default lightset from P5 and even though shadowcams are listed, there is no change when I click on shadowcam. Stays fixed on Main cam. I know P5 could not save a cam in light libraries but this is bad or worse. Can anyone tell me if they get a shadowcam? I know a lot of people don't bother with them but to me, they increase my chances of a successful render 10fold.
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Momodot...It's the hair that came out with Shahara by Trav. It has a lot of morphs and despite being a little "heavy" it's light for what it is...a LOT of hair. I would recommend it. I started to use it as I'm tired of prop hair. Will try an update on the driver. Deecey. Thanks for hangin in there. I think you see now where my poor descrips are getting at. I'm really surprized noone has noticed it but then I have not read all the threads.
