Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Do a search within this forum for "Geep." He's the tutorial master. I know he's done at least one on lighting.
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2063281
Hi JoArtist, You might want to look at these. cheers, dr geep ;=]Remember ... "With Poser, all things are possible, and poseable!"
cheers,
dr geep ... :o]
edited 10/5/2019
Hi JoArtist:-)
If I understand your question correctly, then what you want is not easily available in Poser 5.
I THINK that what you want to do is put a light source inside a bulb and/or a lampshade, and have it work as a light source.
Alas, P5 does NOT have a point-light (a light from a single point) available - a major omission!
The best work-around I have seen involves using 6 spotlights, arranging them such that each points away from the "source" at 90 degrees on all axes, and setting each so that it covers a 180 degree spread. Difficult to explain in words, but imagine a sphere; put all 6 spotlights at the same point in the centre of the sphere, then rotate them one by one so that you end up with spotlights facing left, right, back, front up and down.
Use numerical entry to get precise positioning.
Hope this helps,
Cheers,
Diolma
(edited to correct "axis" from singular to plural ("axes") and it STILL looks wrong! It's not though..)
Message edited on: 05/26/2005 16:21
i am looking for a lighting tutorial.....for POSER 5... i know about lightings spotlight and others... but i have been struggling how to put some light inside bulb and bright upon walls / floor stuffs...with perfect shadows. i never understand how to do with lightings. i hope you can understand me. i mean... a lamp with cover.... i put some light in a bulb....bright against wall of lamp's cover... and light come out of the lamp's cover ...shinning against a table where the lamp standing. shinning against walls from the lamp. can you understand me? i need a tutorial and study how to do it with lighting. thank you so much joey
