Fri, Jan 31, 7:54 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 3:43 am)
Subject: Help need Water!
nyguy ( ) posted Tue, 06 February 2001 at 6:06 PM ยท edited Fri, 31 January 2025 at 7:49 AM
Help I need to add somewater to my first prop I made. If anyone can help I would be most thank full
Poserverse The New Home for NYGUY's Freebies
JeffH ( ) posted Tue, 06 February 2001 at 9:25 PM
Attached Link: http://www.propsguild.com
Does your modeler have a particle engine? Sometimes those things can be turned into a mesh that looks like spraying water. I remember Anton had something like that over at the propsguild.
jrsamples ( ) posted Tue, 06 February 2001 at 10:02 PM
There was also a water prop out there for xtinctions shower. It might work for this. I think that it was done by Viomar.
jrsamples ( ) posted Tue, 06 February 2001 at 10:07 PM
Yep, it was made by Viomar. It is posted at www.cazcie.com It's under downloads, then props by Viomar. Thanks Mark! Nice looking shower!
nyguy ( ) posted Wed, 07 February 2001 at 8:15 AM
Thank you for your help, I have both of the props, the spay prop it hard to get set just right for my shower nossel. I can't get it to align right, maybe you can help, that is if you want to.
bloodsong ( ) posted Wed, 07 February 2001 at 10:59 AM
heyas; grab the spray prop and turn on its origin. move the origin (if needed) to the tip (where it would come out of the nozzle). then position the tip in the nozzle, and when you rotate it, it won't move out.
