Sat, Jan 11, 9:34 AM CST
Forum Moderators: Staff
Subject: INJ-REM Help
Ken _Gilliland ( ) posted Thu, 26 May 2005 at 10:48 AM · edited Mon, 23 December 2024 at 2:32 PM
Online Now!
I decided, rather than update my Songbird ReMix CR2 and update the 150+ MATs, to do an INJ/REM for some special morphs to new characters. I used the DAZ deltas, chanvis folders for a template and built my INJ/REM files for each new morph... They load no problem, but the INJ morphs don't show up. What am I doing wrong?
Here's the INJ/REM files: http://www.empken.com/sbrminj.zip (26kb)
Songbird ReMix
lesbentley ( ) posted Thu, 26 May 2005 at 1:28 PM · edited Thu, 26 May 2005 at 1:35 PM
What do you mean by "the INJ morphs don't show up"? I opened two of your delta files 'INJBug.pz2' and 'INJFinchBeak.pz2'. The channels appear to be slaved to themselves, creating a logical loop (that's bad).
   actor
                channels
                targetGeom
                        name Bug
                        interpStyleLocked 0
I sugest you delete the slaving code (marked in read). Or if your intension was to slave the morph to a valueParm channel in the 'BODY', edit the slaving code so that the actor name is 'BODY:1'. not 'tail:1'. Message edited on: 05/26/2005 13:34
Ken _Gilliland ( ) posted Thu, 26 May 2005 at 3:45 PM
Online Now!
Oh, I see how the "valueOpDeltaAdd" section of code works now... What I was after (using the xample posted) was to insert the "Bug" morph in the "tail" section along with the tail's already existing morphs. I did delete that section of code but still no morphs show up.
Songbird ReMix
Ken _Gilliland ( ) posted Thu, 26 May 2005 at 8:35 PM · edited Thu, 26 May 2005 at 8:36 PM
Online Now!
Okay, I did find out what was wrong... I need to add "hidden" morphs to the .CR2, even though the morphs aren't included
there, for example:
targetGeom Bug
hidden 1
So I guess I need a service release on my .CR2 anyways to get the new morphs...
thanks for your help
Message edited on: 05/26/2005 20:36
Songbird ReMix
lesbentley ( ) posted Mon, 30 May 2005 at 2:01 PM
Yes, injection can only happen into an existing channel;
           targetGeom something<br></br>                        {<br></br><br></br>                       }
You can't inject a whole new channel, but as long as you have at least the minimum shell of a channel, the channel type/name line, and opening and closing braces (as above), you can inject into that.
