Sun, Dec 1, 6:34 PM CST
Subject: Trouble importing obp files...
elinz ( ) posted Fri, 27 May 2005 at 7:06 AM ยท edited Sun, 01 December 2024 at 2:59 PM
I am having problems with the obp files I have downloaded..all of them. I have no problem importing obj,3ds,lwo and so on... Do you know what the problem could be?? And yes,I am a newbie when it comes to Bryces
Zhann ( ) posted Fri, 27 May 2005 at 7:15 AM
If they're objects, open up 'Objects' from within Bryce(at the top of the work window, the little triangle next to objects) at the bottom of that dialog box on the left it'll have either 'installed' or' user' (also click the triangle next to either to bring up all the folders), select 'user', at the bottom on the right you'll see 'import', 'export','delete', select import, browse to where you're keeping your obps, select one and click the checkmark. Repeat for each obp you wish to import... When collecting obps from freestuff etc., and also when exporting your own, keep themm in a folder in 'My Documents' and not in the Program files under 'Bryce', less chance of losing them to weird bugs and things.....
Bryce Forum Coordinator....
RodsArt ( ) posted Fri, 27 May 2005 at 7:19 AM
What Zhann said. :)
___
Ockham's razor- It's that simple
elinz ( ) posted Fri, 27 May 2005 at 7:32 AM
"open up 'Objects' from within Bryce(at the top of the work window, the little triangle next to objects.." U lost me there....I can`t find "objects" anywere..... I use Bryce 5.0
elinz ( ) posted Fri, 27 May 2005 at 7:33 AM
Aha...I get it..thanks for the image there ICM ..hugs realy hard
CorwinRathe ( ) posted Fri, 27 May 2005 at 7:50 PM
I'm having trouble with orbitals rockpile file. It crashes Bryce everything I try a import. Anyone else having this problem? I was really looking forward to trying it out too.
Zhann ( ) posted Fri, 27 May 2005 at 10:33 PM
Haven't opened it yet....
orbital ( ) posted Sat, 28 May 2005 at 4:29 AM
The rock stack ain't working properly for some reason. I've sent AS an untextured version to try. If that doesn't work I'll do a tutorial on how it was built.
http://joevinton.blogspot.com/
