Thu, Feb 13, 4:38 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 3:49 pm)
Subject: RE: Finding figures made invisible
magnus13 ( ) posted Fri, 27 May 2005 at 8:50 PM ยท edited Thu, 13 February 2025 at 4:35 PM
Hi there, Is there a full list of all figures/props used in a scene anywhere? I've made a few things invisible & also others too small to see in the scene, so how can I view them again? Thanks. :) Michelle
mateo_sancarlos ( ) posted Fri, 27 May 2005 at 8:56 PM
Use the command "Show all figures".
magnus13 ( ) posted Fri, 27 May 2005 at 9:07 PM
Cool. Thanks mate.
wyrwulf ( ) posted Fri, 27 May 2005 at 9:52 PM
You can use the hierarchy editor to select and make things visible.
magnus13 ( ) posted Fri, 27 May 2005 at 10:39 PM
I tried the hierarchy editor before posting here thinking that would work, but it didn't. I clicked the eye next to the figure (?). I guess I did it wrong. Thanks though.
Fazzel ( ) posted Fri, 27 May 2005 at 10:40 PM
In fact the hierarchy editor is better because you can selectively make things visable again, in case you wanted to leave some things still invisable.
DCArt ( ) posted Fri, 27 May 2005 at 10:41 PM
Sometimes you have to click it on, then off, then on again to get it to work.
magnus13 ( ) posted Fri, 27 May 2005 at 10:49 PM
Ahh... ok. Thanks.
GRiMAge ( ) posted Mon, 30 May 2005 at 8:13 PM
As for the small things, remember that you can select them from the drop down menus below the main window - figures on the left and bodyparts/props/lights on the right. If some prop has been parented to a figure you'll have to select the parent figure on the left to make it appear on the right. Hope this is useful. Grim
