Fri, Jan 24, 6:11 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Wardrobe Wizard.. fun stuff and impressive
byAnton ( ) posted Mon, 30 May 2005 at 12:32 AM · edited Fri, 24 January 2025 at 6:10 AM
You know. I think this has got be be one of the coolest things is a long time for Poser.
One of the testers sent me this quickie pic and Phil showed me one of the Tux when he incorprated Apollomax into the program.
I am just so impressed with creative stuff like this. I know it isn't the same as custom items neccesarily, but I think this is just so inspiring.
What is so impressive to me is Apollomax is designed as different from the the standard as the MilDragon is to the cat. And still it works. Now if Phil ads the HouseMouse it can have clothes too. :)
Just like the texture convertor Darkwhisper did, I think this one is going to be a classic.
Kudos to PhilC and Kamilche
Anton
Message edited on: 05/30/2005 00:40
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
byAnton ( ) posted Mon, 30 May 2005 at 12:33 AM
oops. Forgot the test pic.
Tashar59 ( ) posted Mon, 30 May 2005 at 12:49 AM
Still trying to decide myself if I should buy. You lose all the clothing morphs. So you can't do animations with it, only stills. You won't be able to take advantage of As Shanim clothes and such. Still it would be very useful to convert base object to other figures, then create new morphs.
byAnton ( ) posted Mon, 30 May 2005 at 12:55 AM · edited Mon, 30 May 2005 at 12:56 AM
I don't understand what you mean about not being able to do animations. Why would morphs matter? You mean capes and such?
I look at it like this. Even if you only convert props and a few items, it has already paid for itself in savings.
Message edited on: 05/30/2005 00:56
Kalypso ( ) posted Mon, 30 May 2005 at 1:03 AM
Site Admin
There's an option to convert to a figure without welding then you can transfer morphs via MorphManager and weld the mesh. And you can only transfer the morphs you really use and not all which is a plus. You can also convert to prop and make it dynamic - even better for animations. And both creators are accessible on the Yahoo Group for WW and constantly there answering any questions that may come up - couldn't ask for better support :)
Tashar59 ( ) posted Mon, 30 May 2005 at 1:24 AM
Kalypso, have you done this? I had asked over there and was told that it didn't. Not that it matters, I bought a few minutes ago and checked here while waiting for the D/L link. Which may be tomorrow, I do think Phil sleeps sometimes. Anton, check the marketplace here for As Shanim or pretty3d. You will understand what I mean. If MM does work I'll be doing the Snoopy Dance.
Farside ( ) posted Mon, 30 May 2005 at 1:28 AM
I bought it and so far have tried it briefly. Attempted to transfer one of BatLab's outfits from V3 to S3P and it worked ok, a bit of a problem between the breasts but probably fixable using mags... decided to try it a second time using what I had learned from the first attempt and it crashed. I'll give it another try tomorrow when I'm more awake.
byAnton ( ) posted Mon, 30 May 2005 at 1:31 AM
Oh I see. Simulated dynamics through morphs. Well there are alwasy going to be gaps. But like I said, even if you convert only a few standard things for a figure or two, it has paid for itself. I currently have nothing other than Apollomax installed. I might reinstall Mike 2 to test all my old Mike2 clothes that were in the Platinum Club. They didn't have morphs anyway so it will be fun to see the result, escpecialy on the ninja suit.
Tashar59 ( ) posted Mon, 30 May 2005 at 1:46 AM
Breasts always seem to be a problem with these apps. Clothroom may be an answer for that though.
Kalypso ( ) posted Mon, 30 May 2005 at 2:50 AM
Site Admin
Grrr, I had a nice, detailed answer typed out and then the Rosity server ate it :( Anyway, here's the gist: Now that I tried it with As Shanim's EveryDay Vest the morphs transfer fine and the morphs on the abdomen work perfectly but the chest morphs explode. I guess for your needs beryld, it's not that functional. However, I see Phil and Kamilche still working on it so there's hope :) Oh, and I even tried it on a S3 that had one of Wyrmmaster's magnet sets with lots of tweaking by me and the converted the V3 Harem Dancer outfit to her and conformed just fine, so it works great on already morphed figures even those morphed with magnets.
estherau ( ) posted Mon, 30 May 2005 at 3:41 AM
I think it means all the clothing that doesn't have morphs will suddenly be attractive and people will buy it knowing they can make it fit their morphed characters, and also a lot of free stuff will become more attractive for the same reason. If it works fairly well it will make such a huge difference in our little poser world. Well I'm waiting for my registration key, (phil wake up!) so I can try it out. Say Anton, those diamond thingies for V2 are figures aren't they (I'll have to check). My V3 could do with some diamonds. So Anton, when is appolomax coming out? He looks rather yummy? Love esther
MY ONLINE COMIC IS NOW LIVE
kuroyume0161 ( ) posted Mon, 30 May 2005 at 4:10 AM
But as soon as you morph the figure, don't you have a dilema since there are no morphs on the WW'd clothes to make adjustments with. Now, I don't see this as a problem, more of a limitation since morphs are morphs (strictly dependent upon the geometry in use). Magnets? What are magnets? The only thing that I use magnets for are picking up string vibrations and pounding them out an amplifier. Methinks Dynamic cloth may be the only solution to 'after-fitting' the conform-fitted clothes when morphs are involved. On a side note, I do love that among the examples of conforming a dress is Don. I always knew he was a crossdresser! ;)
 -- Bjarne Stroustrup
byAnton ( ) posted Mon, 30 May 2005 at 4:20 AM
esther, Yes the diamonds may work since they are figures. Some are changing geom and I don't know how that works though with Wardrobe Wizard. But yes, Diamonds should eb convertable. You'd have to try it and see. But it's why I always said props are better as cr2's. All the power is in the cr2.
PhilC ( ) posted Mon, 30 May 2005 at 4:38 AM
OK I'm awake again [blink] and answering email. Its been a very hectic weekend :)
Some issues? Yes but all addressable and more to the point are being addressed. The public beta was a great help so our thanks again for those who participated. Did anyone view the on screen videos yet?
Be sure to vote in the Yahoo forum for which figure you want included next.
byAnton ( ) posted Mon, 30 May 2005 at 4:54 AM
lol. HouseMouse!
TrekkieGrrrl ( ) posted Mon, 30 May 2005 at 5:20 AM
Attached Link: Pic: "I wil only say this once..."
I must say, this is the greatest thing since sliced bread! In less time than it took to say "Quidditch" I had the Biker Jacket converted from M3 to a perfect fit for HarryDavid. I also converted PhilC's V3 corset and stockings to fit SnapeM3, the scary result can be seen in my gallery here (scary because of the content, the clothes fit PERFECTLY!) THANKS PHIL! And Kamilche too!
estherau ( ) posted Mon, 30 May 2005 at 5:42 AM
is that the jacket by dodger? i have it and am goingto try it on V3 love esther ps when i get my key!
mylemonblue ( ) posted Mon, 30 May 2005 at 6:20 AM
PhilC and Kamilche you're both brilliant! By the way thank you for including Maya Doll to!
Also Sixus1's humans such as Behemoth, mobius's Solondra III, and Dacort's Natalia shouldn't be included. :)
My brain is just a toy box filled with weird things
sparrowheart ( ) posted Mon, 30 May 2005 at 7:09 AM
HOUSE MOUSE!!!! I second Anton's motion :-) (And seriously, I mean it. House Mouse is my favourite model of all time.)
estherau ( ) posted Mon, 30 May 2005 at 7:29 AM
got my key, I'll let you know what happens next. Love esther ps trying to convert BVH swat for V2 to V3
mathman ( ) posted Mon, 30 May 2005 at 8:03 AM
Where is this product available ? I keep a close eye on the marketplace here, and I haven't seen it yet.
estherau ( ) posted Mon, 30 May 2005 at 8:11 AM
Attached Link: http://www.philc.net/WardrobeWizard.htm
Here's the link. I don't think PhilC bothered trying to market it much as he knows almost every single poser user around the world is going to buy it anyway and he probably didn't want to be swamped to early. well that' smy guess. Love esther
genny ( ) posted Mon, 30 May 2005 at 8:35 AM
ernyoka1 is Right....This is the greatest thing since sliced bread! LOL! Having never used python scripts, Ever.....I found this to be very easy and user friendly and it works great! Thank you, thank you, thank you, PhilC and Kamilche! (:
Kristta ( ) posted Mon, 30 May 2005 at 9:12 AM
I want this so bad it's killing me and I just don't have the money right now. It will be next week maybe when I can get it. Is it very hard to use or fairly simple? I need the fairly simple. I've tried clothing converter and the tailer and I just can't get the hang of those. Any tutorials out there showing how to use it?
genny ( ) posted Mon, 30 May 2005 at 9:20 AM
Kristta, try out the demo version untill you have the money. There is instructions, and believe me.......if I can do it...anyone can! LOL! I like you could never get the hang of the Tailor, but this is easy as pie.(: Really!
Jcleaver ( ) posted Mon, 30 May 2005 at 9:28 AM
I have a brief question. It looks great, and worked for the most part in the public beta I had. After you convert a piece of clothing, can you save it so that it doesn't need converting again? I would guess yes, but just want to make sure before i buy.
MarianneR ( ) posted Mon, 30 May 2005 at 10:18 AM
Jcleaver: Yes, you can save your converted items and reuse them.
nwm ( ) posted Mon, 30 May 2005 at 10:46 AM
...and hopefully soon in P6, when SR1 is available.
I just got my registration code and had to try it out. I can't believe how easy it is! I was a little skeptic first, I have tried other applications (for PC) that promise to convert clothes with a few clicks. I'm impressed by the results of Wardrobe Wizard - like Anton said above, this is going to be a classic.
Moonbiter ( ) posted Mon, 30 May 2005 at 11:25 AM
Clarification question because I want to make sure I got the gist of this right: With this utility I can take a confoming pair of pants from M3 and convert them to a morphed freak and they will conform plus already fit my custom character without the need more morphs?
nickedshield ( ) posted Mon, 30 May 2005 at 11:30 AM
I'm impressed with it. This is one of the most difficult type of figures to cloth... Wolfgang (M2) wearing RPD's M2 Mountain Man suit. It's not perfect but considering the body shape it's very close. This is the first conversion utility I've used that managed to get this far.
Warangel ( ) posted Mon, 30 May 2005 at 12:57 PM
PhilC, you know I adore you, and I see this is usuable with Jessi. That makes me very happy. Does anyone have any pics of something converted for use with Jessi? I would be very interested in seeing that please.
Gareee ( ) posted Mon, 30 May 2005 at 12:58 PM
Like any utility there are good and bad things about it, but when you consider the price, and the cost of clothing, converting 4 or 5 things successfully makes it pay for itself. Is it the final solution? Nope. Is it much easier and a good solution for many items? Yep! As Anton said, it's a good useful tool, much like UTC.
Dave-So ( ) posted Mon, 30 May 2005 at 1:12 PM
did the beta...awesome... just bought it...it does hair as well...that's where I'm headed :)
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
Tiny ( ) posted Mon, 30 May 2005 at 1:56 PM
In post #3 is said 'you can't do animations'. I have some plans for WW but need to have the clothes stay on in animations.
So, will the clothes not stay on in animations without going through cloth room?
xoconostle ( ) posted Mon, 30 May 2005 at 2:00 PM
This is the coolest thing since sliced bread. The included utilities will be very useful. Phil, thanks for the time and care that you put into the tutorials as well. :-)
RHaseltine ( ) posted Mon, 30 May 2005 at 2:13 PM
If you have a skirt that you want to stay on the figure during an animation (or even in a still image) you need morphs or magnets to adjust its hang. By default WW leaves the morphs behind, though there is an option to work around that apparently, so you'd have to use magnets to pull the skirt around the legs. Items like trousers that conform all over would work fine in animations.
Tiny ( ) posted Mon, 30 May 2005 at 2:17 PM
Thank you, RHaseltine. All I needed to know. :o)
Tashar59 ( ) posted Mon, 30 May 2005 at 2:23 PM
"In post #3 is said 'you can't do animations'. I have some plans for WW but need to have the clothes stay on in animations. So, will the clothes not stay on in animations without going through cloth room?" Tiny, they are conforming. They stay on the figure and normal group movement. You just lose all the cloth morphs, eg. lift skirt right, open blouse front, and so on. Mind I'm still trying to D/L the app. I was thinking the cloth room and magnets might be used to create some of the morphs. They wouldn't be the same as the original morphs.
Tashar59 ( ) posted Mon, 30 May 2005 at 2:39 PM
Kind of a crosspost with RHaseltine. I hate this slow dialup, but thats all I can get in these here part. LOL.
Lyne ( ) posted Mon, 30 May 2005 at 2:46 PM
Whaaa.. I bookmarked about this utility at DAZ.... but it is only available via Phil's site?? (pay pal woes..won't use it nor use my own cc with it).... sigh..
Life Requires Assembly and we all know how THAT goes!
Smoovie ( ) posted Mon, 30 May 2005 at 2:47 PM
I'm impressed
Dave-So ( ) posted Mon, 30 May 2005 at 3:02 PM
Lyne, not sure I'm following you correctly here, but you can just use your credit card...you don't need to use PayPal.
Tiny ( ) posted Mon, 30 May 2005 at 3:39 PM
Bought it an hour ago.
But I didn't get a download link. Used credit card.
Got confirming email directly but no download.
How did this work for you guys?
Dave-So ( ) posted Mon, 30 May 2005 at 3:45 PM
I'm still waiting as well...I know Phil is working on the latest update and getting that all set up...so it will probably be awhile.
Tiny ( ) posted Mon, 30 May 2005 at 3:47 PM
Ok, thanks. I'll try to be patient. :o)
Tashar59 ( ) posted Mon, 30 May 2005 at 4:11 PM
I think Phil does all the purchaces by hand. May take a bit of time getting through it all.
Dave-So ( ) posted Mon, 30 May 2005 at 4:16 PM
it would be interesting to find out how many of these packages have been sold so far... I bet a lot
byAnton ( ) posted Mon, 30 May 2005 at 4:20 PM
Poor Phil. No wonder is is getting no sleep. :) Those pics are great. Even if the conversion isn't 100% perfect, you would never know it by the pics.
dlk30341 ( ) posted Mon, 30 May 2005 at 4:28 PM
You can add me to the order/waiting list :)
mylemonblue ( ) posted Mon, 30 May 2005 at 4:46 PM
Landslide.... :)
nickedshield ( ) posted Mon, 30 May 2005 at 4:57 PM
For those who haven't looked, there are some htm files that explaine some advanced features, the weld may be of interest to animators.
