Tue, Oct 22, 1:56 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 1:40 am)
Subject: Poser 6 Help ... Uninstall / Reinstall Problems
Chris ( ) posted Sun, 29 May 2005 at 9:28 AM · edited Fri, 18 October 2024 at 8:31 AM
Hi all, I have some problems with Poser 6 ... it don't saves anymore. So I thought I uninstall / reinstall it on my PC. Uninstalled it and deleted the Poser 6 Folder. Cleaned the Registry. So far so good. After reinstalling Poser 6 with all patches it still don't export or saves. But I have still the last preview render I did there. Weired! There must be another place where Poser saves informations. Can someone point me to that folder? Thanks in advance Greets Chris
"It Is Useless To Resist!" - Darth Vader
Dizzi ( ) posted Sun, 29 May 2005 at 9:53 AM · edited Sun, 29 May 2005 at 9:54 AM
It's stated in the SR1 readme, where the renders are stored:
For Windows it's
Documents and Settings{USER}Local SettingsTempPoserRenderCache I had P6 also not saving sometimes...
Message edited on: 05/29/2005 09:54
nruddock ( ) posted Sun, 29 May 2005 at 9:54 AM
Look for a directory called "PoserRenderCache".
I'm not sure of the path, as my Temp folder is not in the default location.
Chris ( ) posted Sun, 29 May 2005 at 10:08 AM
ok, found it ... but ... still can not save or export. Pulling my hair out here. What can I do else? Greets Chris
nerd ( ) posted Sun, 29 May 2005 at 1:39 PM
Forum Moderator
What happens when you try to save?
Chris ( ) posted Mon, 30 May 2005 at 2:31 AM · edited Mon, 30 May 2005 at 2:33 AM
Hi Nerd,
when I try to save or export Poser 6 closes to desktop without promt.
forgot to give my system specs:
Compaq SP750 Workstation
2x Intel P3 XEON 866
512 MB Ram
NVidia GeForce 5700 with 128MB Driver Version 66.72
Windows XP Pro with SP2
24 GB Virtual Memory free
Hope you will be able to help
Greets
Chris
PS: Sorry for late reply :) Edit: Poser 6 worked great from the first time ... but after about 3-4 Weeks using it it has this issue.
Message edited on: 05/30/2005 02:33
nerd ( ) posted Mon, 30 May 2005 at 3:10 AM
Forum Moderator
Make sure there isn't any thing weird in your preferred state. Open prefs and set the prefered state to factrory and the UI to factory. Exit and relaunch. Try saving now. If it works delete all the UI dots too. Then arrange things the way you like them and reset the preferred state. Nerd3D
Chris ( ) posted Mon, 30 May 2005 at 3:17 AM
Nerd, thanks for the fast reply. Poser 6 is on a fresh installation right now. I have not changed anything in the UI and such but I'll try your suggestions when I'm back home. Thanks Chris
nerd ( ) posted Mon, 30 May 2005 at 11:35 AM
Forum Moderator
One more detail, did you install SP1 for Poser. There were some OpenGL issues and IIR one of them had to do with this. SP1 is supposed to have fixed them. You could verify if it's an OpenGL issue by setting your display type to SreeD and trying to save. Nerd3D
Chris ( ) posted Mon, 30 May 2005 at 1:33 PM
ok ... I have tried all your suggestions, Nerd nothing worked snif Any other ideas what I can do? Thanks Chris
nerd ( ) posted Mon, 30 May 2005 at 6:00 PM · edited Mon, 30 May 2005 at 6:01 PM
Forum Moderator
OK, I'm stumped. You could try some basics, Virus and spyware scans. It not likely but you never know. It's really weird that it was working and just stopped. Do you remember installing anything or perhaps updating a driver?
Nerd3D Nerd < Needs typing lesson
Message edited on: 05/30/2005 18:01
nerd ( ) posted Mon, 30 May 2005 at 10:43 PM
Forum Moderator
Perhaps this link has some useful info: http://poserpros.daz3d.com/forums/viewtopic.php?t=39221
Chris ( ) posted Tue, 31 May 2005 at 7:35 AM · edited Tue, 31 May 2005 at 7:38 AM
hmmm ... interesting thread over there :)
I'm not sure ... but I will try some of their suggestions.
I'm not sure too if I have installed a new driver or such ... I know last thing I did in Poser was loading Wyrmmasters Vicky Vogue 2003 Deformers ... then BANG Poser 6 closed and no saving anymore even after a reinstall.
weired, huh? :)
Greets
Chris
Message edited on: 05/31/2005 07:38
snoops ( ) posted Tue, 31 May 2005 at 1:46 PM
Hi Chris I had the same problem and installed the latest videocard drivers. It fixed the problem for me. I can now save without any problem. Snoops
Chris ( ) posted Wed, 01 June 2005 at 1:56 AM
thanks for the tip, snoops ... I will try that too. greets Chris
Chris ( ) posted Thu, 02 June 2005 at 4:38 AM
Hi all, my Poser is up and running again :) After trying all suggestions given here without any success the last one was to uninstall and reinstall my Video Drivers as snoops suggested ... BINGO! Looks like my drivers got corrupt by any reason. Thanks to all who tried to help! Greets Chris
