Fri, Nov 22, 11:48 AM CST
Subject: P6 Reflection problem
tbird10 ( ) posted Wed, 01 June 2005 at 3:22 PM ยท edited Fri, 22 November 2024 at 5:43 AM
I thought that this was supposed to have been fixed in the SR1 release. Here is a bath in P6 SR1, it was the same before the SR update. The internal reflections are all wrong
tbird10 ( ) posted Wed, 01 June 2005 at 3:24 PM
Here is the same bath (albeit containing Vicki :-) ) in P5
The internal surface reflections are smooth and unbroken.
stewer ( ) posted Wed, 01 June 2005 at 4:13 PM
Do you have any shadows or AO enabled? It looks a little like self-shadowing, in case you're using AO, try increasing the bias. Also, make sure you set a sufficient number of raytrace bounces in your render settings.
odf ( ) posted Wed, 01 June 2005 at 11:02 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2276481
You mean the reflections of the floor in the outer surface of the tub? I suspect the floor uses an image based texture? As it appears, P6 (with or without SR1) has a problem refracting image based textures, see the attached link. I haven't tested if the exact same thing happens with reflections, but it appears quite probable.
tbird10 ( ) posted Thu, 02 June 2005 at 5:11 AM
Ahh, I am using AO so it's probably that, I'll try fiddling with the AO settings. Thanks :-)
tbird10 ( ) posted Thu, 02 June 2005 at 2:42 PM
Nope, it wasn't AO, here it is with AO switched off, it's removed the shadowing, but the reflection is still wrong. I'm sure that soon after P6 was released I saw something that said the reflections (and refractions) had a bug and these would be fixed in the SR, have to search back through the forums.
tbird10 ( ) posted Thu, 02 June 2005 at 3:40 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2254915
Found the referral to a bug
"There is a bug in reflections and refractions in Poser 6.
I had the same problem and emailed Curious Labs about it.
They said is a known bug and they said it will be fixed
in the service release. Sorry, but all these tips and hints
won't help any. Just have to wait until Curious Labs releases
the fix. "
Guess it's time to e-mail CL
