Sun, Jan 26, 7:07 PM CST
Subject: DEM's
Sentinal ( ) posted Thu, 02 June 2005 at 3:42 PM ยท edited Sun, 26 January 2025 at 6:58 PM
Okey, I'm using vue 5 inf, I've gone and downloaded some DEM files, got them into vue and it looks like there is a 'wall' around the terrain. Any ideas? regards Sentinal
bruno021 ( ) posted Thu, 02 June 2005 at 4:40 PM
From this screenshot, it seems you used the terrain editor to import your DEM. The manual says you should import it with the import object menu.
bruno021 ( ) posted Thu, 02 June 2005 at 4:55 PM
Oh, I tried it too, and same problem, but it seems that if you use the clip slider in the terrain editor, you should be able to get something decent.
nanotyrannus ( ) posted Thu, 02 June 2005 at 6:19 PM
A couple of other options (this noise thing has always been irritating) use a freebie program called 3dem to crop down the dem so the bad data on the edges is cropped out, or use the dig tool in the terrain editor to manually dig down the wall.
Darthmagus ( ) posted Fri, 03 June 2005 at 3:47 AM
Attached Link: http://visualizationsoftware.com/3dem/
Here the link to 3dem.
Sentinal ( ) posted Fri, 03 June 2005 at 9:35 AM
Thanks for all the help, I've just got a hold of 3dem and I'll be trying it out later. regards Sentinal
Jeremy_Doyle ( ) posted Thu, 09 June 2005 at 4:42 PM
I have the same problem however I'm running on a mac and 3dem isn't an option. Any suggestions?
regaltwo ( ) posted Thu, 09 June 2005 at 10:27 PM
I get the same problem, and I just boolean difference out the "walls" with some large cubes.
