Mon, Feb 10, 5:13 PM CST
Subject: Render Wireframe in Poser6????
StealthWorks ( ) posted Fri, 03 June 2005 at 6:02 AM · edited Mon, 10 February 2025 at 5:05 PM
Hi, how can I render a wireframe image in Poser 6? In previous version you could render using the display settings but I can't figure out how to do this in P6. Also, I don't just want to export the image before rendering because the wireframe image needs to be much bigger than the screen so I'll need to do an actual render. Any help would be much appreciated Thanks in advance
ashish_s_india ( ) posted Fri, 03 June 2005 at 6:12 AM
use a UV Map template as texture and render. And same UV Map as transparency map. Will render to a wireframe :)
Mazak ( ) posted Fri, 03 June 2005 at 6:49 AM
Use the preview render in poser6, you can change Sytle Options in render settings. Mazak
Google+ Bodo Nittel
maxxxmodelz ( ) posted Fri, 03 June 2005 at 6:52 AM
Just set your document display style to whatever "wire" style you want to render (ie., smooth lined, flat lined, lit wireframe, hidden line, or just wireframe), then set your render settings to "preview", with antialias checked, and then render the figure/scene.
Mazak ( ) posted Fri, 03 June 2005 at 6:52 AM
StealthWorks ( ) posted Fri, 03 June 2005 at 1:56 PM
thanks for the info - this is exactly what I was looking for. Mazak, thanks for taking the time to do those screenshots Cheers Mat
UVDan ( ) posted Mon, 06 June 2005 at 11:43 PM
Forum Moderator
and I hereby proclaim you a Knight of the UV Empire!
