Wed, Nov 27, 8:32 AM CST
Subject: I have a problem whith hmann dynamic pleated_skirt for V3
idocatrudiaris ( ) posted Sat, 04 June 2005 at 3:15 AM · edited Thu, 01 August 2024 at 1:15 PM
In this atassament I tray to simulate whith simulate draping(15) folder resistance and all parameter at maximal value but I can't obtain a good simulation. I tray everyfing but I do nothing rezult. Please help my for this problem I follow all step for a corect image load V3 in frame 01 aply the Rose pose(voluptuouse woman) aply the pose in frame 15 turn on clothing room and configure all parameter in many way. calculate simulation
AS3Design ( ) posted Sat, 04 June 2005 at 3:32 AM
did you apply Rose to frame 1? if so, I would try to apply her in frame 15 or maybe frame 10. maybe that helps :)
Turn your face to the sky... and the shadows will fall behind you...
idocatrudiaris ( ) posted Sat, 04 June 2005 at 3:39 AM
I apply the Rose in frame 10 and in 15 frame I aplly the pose
AS3Design ( ) posted Sat, 04 June 2005 at 3:44 AM
hm then Ive no idea :( but the skirt does fit in zeroed position?
nruddock ( ) posted Sat, 04 June 2005 at 3:50 AM
"folder resistance and all parameter at maximal value but I can't obtain a good simulation"
Not surprising really, it will be literally as stiff as a board.
Run a simulation with the Default parameters first and then make small adjustments to the parameters.
idocatrudiaris ( ) posted Sat, 04 June 2005 at 3:55 AM
SKIRT IS FIT IN ZEROED POSITION IN FIRST FRAME. AND V3 THE PROBLEM APPEAR AFTER FREAME 10 IN FACT BETWEEN FRAME 10 AND FRAME 15 AND I DON'T FIND SOLUTION FOR THAT. I TRAY TO ADD ALL THE SKIRT NODES ON CONSTRAINED GRUP BUT OTHER SOLUTION NOT EXIST. I tray to aplly other pose in 15 frame but if thigh is bend the skirt not conform it after the simulation Anyway than's for you attention
idocatrudiaris ( ) posted Sat, 04 June 2005 at 4:13 AM
In the firt I tray to run a simulation whith default parameters but if the thigh is move from 0(in frame 15 I put the pose) the skirt not conform it.After that i tray it to make a adjustment and nothing.This pose is the best pose which have.
nruddock ( ) posted Sat, 04 June 2005 at 4:27 AM
Ok, first thing to check is, have you got all the necessary body parts set in "Collide against ..." ?
If that's not the problem, please post a full screenshot of the Cloth Room at frame 1, with the simulation cleared.
Dale B ( ) posted Sat, 04 June 2005 at 6:47 AM
From the picture, you have collision violations all over the place. Look around the waist area. See how the top interpenetrates the skirt? =ANY= geometry that violates the collision detection by penetrating the object being clothified will cause the simulation to freeze at that point. Another possible cause is that you are only using 5 frames to morph the character into a different shape. It is very possible for the charcter to be enlarged or changed fast enough between frames for the body geometry to 'pass' the cloth; instant freeze in the simulation. Try draping the cloth items for 15 frames, then using the default 30 frames to morph the figure. Move the time slider to frame 10, press the + button to add a keyframe, then move it to frame 30 and apply the final morph. By doing this, the morphing will start at frame 10, which gives 20 frames for things to move, slowing down the rate of change.
