Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 6:51 am)
SKIRT IS FIT IN ZEROED POSITION IN FIRST FRAME. AND V3 THE PROBLEM APPEAR AFTER FREAME 10 IN FACT BETWEEN FRAME 10 AND FRAME 15 AND I DON'T FIND SOLUTION FOR THAT. I TRAY TO ADD ALL THE SKIRT NODES ON CONSTRAINED GRUP BUT OTHER SOLUTION NOT EXIST. I tray to aplly other pose in 15 frame but if thigh is bend the skirt not conform it after the simulation Anyway than's for you attention
From the picture, you have collision violations all over the place. Look around the waist area. See how the top interpenetrates the skirt? =ANY= geometry that violates the collision detection by penetrating the object being clothified will cause the simulation to freeze at that point. Another possible cause is that you are only using 5 frames to morph the character into a different shape. It is very possible for the charcter to be enlarged or changed fast enough between frames for the body geometry to 'pass' the cloth; instant freeze in the simulation. Try draping the cloth items for 15 frames, then using the default 30 frames to morph the figure. Move the time slider to frame 10, press the + button to add a keyframe, then move it to frame 30 and apply the final morph. By doing this, the morphing will start at frame 10, which gives 20 frames for things to move, slowing down the rate of change.
![file_249774.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_249774.jpg)
In this atassament I tray to simulate whith simulate draping(15) folder resistance and all parameter at maximal value but I can't obtain a good simulation. I tray everyfing but I do nothing rezult. Please help my for this problem I follow all step for a corect image load V3 in frame 01 aply the Rose pose(voluptuouse woman) aply the pose in frame 15 turn on clothing room and configure all parameter in many way. calculate simulation
