Wed, Nov 13, 11:22 PM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
Subject: LINUX and UF3
FreedomOfExpression ( ) posted Thu, 02 June 2005 at 7:11 PM · edited Tue, 12 November 2024 at 9:07 PM
So, it does run on emulators (well, so I knew that it did, but...). How does it do? How fast is it? What's the emmulator's overhead? I've been considering a linux system, as I know it runs some things faster than Windows due to its far slimmer archecture. But UF3 stopped me, as I know emmulators are plagued by horrible performance due to what they are doing. However, a good windows on linux emme should be fast, since the native code (x86+) is the same. So what's it like?
sammi ( ) posted Fri, 03 June 2005 at 7:39 AM
it depends on which flavour linux, i can get it to run on debian. i haven't a clue what an emulator overhead is ? wine runs apophysis with practically no difference in peformance, x-windows has sometimes a bit of a problem catching up, some redraw flicker, i have other problems, ie have corrupted the my flmes flame file, mind you it was a bit big, ca one gig i think my husband said. i have no idea what kind of problems you my run into using uf because i don't use uf, and, my windows platform is win 98, i don't reackon much to any windows distro after win98 (i think they're all rubbish)
FreedomOfExpression ( ) posted Fri, 03 June 2005 at 8:15 AM
XP or 2k > 98. 98 is a 9x where 2k&XP are nt4 derivatives (XP less so). nt4 uses NTFS which owns FAT32. Plus, 98 has no security. Having a corrupt 1gb file on 98 would be common, on 2k/XP, it would be rare (I've had 6gb files, and nothing happens to them. NTFS handles volume better than FAT32, since FAT32 was built when the max size for a system was 10gb using about 4 drives). Emmulator overhead has to do with how much raw clock/memory time the emmulator itself uses (which then makes that clock not availible to the program it's running). I actually don't know anything about linux, though I did know there were zillions of versions, and that redhat was once really common, and that tarballs suck (at least they do on windows).
sammi ( ) posted Fri, 03 June 2005 at 10:20 AM
". Plus, 98 has no security" yes, i don't boot into the win98 platform at all. i seriously don't like xp, my girls have it on their machine and i'm not impressed, caused me endless headaches trying to maintain it. i think my problem was having win on a too small partition for what i was doing, ie rendering willy-nilly and not tidying up :) not sure why you think tarballs suck and how that is relevant to linux ?
FreedomOfExpression ( ) posted Sat, 04 June 2005 at 12:53 AM
.tar.gaz files take me forever to get open under windows (they're a linux zip format). "i think my problem was having win on a too small partition for what i was doing, ie rendering willy-nilly and not tidying up :)" yep, been there done that (tried it on a 5gb real drive. crashed windows in a record time of 10hrs.) you can make xp look like 9x quickly. Then its exactly the same plus the features. also, disabling the security in SP2 helps.
sammi ( ) posted Sat, 04 June 2005 at 4:50 AM
i don't understand why you'd want to use tar.gz files in windows :) "yep, been there done that (tried it on a 5gb real drive. crashed windows in a record time of 10hrs.)" yes i had allocated only 4gig of a 60 ig dive to windows and didn't take that into account when rendering and saved everything rendred in apo on that partition :) i'm really not interested on working on windows platforms, it's very rare to crash linux box, though i have manged that too quite often recently. i have now another 500 memory installed which brings me up to 1 gig of memory which should solve that problem as i want to make a longer film clip for my tutorial,probably using xaos output for the base image.
