Sat, Feb 1, 2:33 PM CST
Subject: Sorting Thumbnails & Presets
FranOnTheEdge ( ) posted Fri, 03 June 2005 at 8:50 AM · edited Sat, 01 February 2025 at 12:05 PM
  1. Thumbnails. Help??? Okay, I know Zhann or someone already told me how to have the adjusted view of an object, material, whatever, that you've changed in the little preview window become the thumbnail in the list - only I've forgotten how, and it seems I foolishly didn't save the info. Help? 2) Saving multiple Presets. Help? How do you do it? I mean when you want lots of them like for instance, lots of objects but not ALL the objects in a section. Or if for instance you downloaded a load of Glass objects (or materials) and they all turned up in their own separate list - one glass in one list (all alone) and one in the next etc, etc, So I wanted to save each of those glasses and collect them into one .obp file. - can it be done? And please, if it can be done could you make the instructions on how to do it, nice and simple - i.e. step by step? - 'cos I get easily confused.
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
Zhann ( ) posted Sat, 04 June 2005 at 2:34 AM
I'm guessing by 'saving' you mean exporting to a folder for future use, etc.... 1) make sure you're in full view in the preview window, that becomes your thum, some imported meshes do not show for some reason.... 2)Hold down the cntrl key and select which presets to export, give the libray a name, (holding down the shift key will export an entire library as a single preset, helpful if you don't like importing one at a time)... 3)yes, you need to take one of the single presets and use it to create your library, then just import all the rest into the blanks next to that one preset and then go rename that new library, I do that with plants, like importing all the tropicals into one library and renaming it 'TropicalPlants', or 'zhanns stones', 'my metalmats',etc., then I can export the whole mess as one preset, so if I need to ever reload, I only need to import one preset and all my plants will be there..... Last, if you can import and export there's nothing to doing either that's difficult.....=)
Bryce Forum Coordinator....
FranOnTheEdge ( ) posted Sat, 04 June 2005 at 2:23 PM
Zhann, "1) make sure you're in full view in the preview window, that becomes your thum, some imported meshes do not show for some reason...." yes, by "Full view" do you mean "Close up" or "Normal"? And then what? How do you get what you see in the preview window to be what you see in the thumbnail?
Fran's Freestuff
